We have a problem with the projects because it does not save the measurements, I want to know how to save the measurements on a 3D map.
Thank you.
Thank you.
Hmm… i cant get the 3d measurements work at all in the 3d environment.
It doesnt matter what tool I use, it only sets out one single dot and that’s it.
I’m not sure if the measurements are meant to be saved to the project. If I understand correctly, they’re just single-use to help you confirm in-situ data.
What browser are you using?
I have webodm 1.8.2
And I have tried crome, edge and I think also firefox .
Move about the problem … webodm 1 8 2 - YouTube
