pyy
25 January 2019 08:45
1
The question is as following
How did you install ODM? (Docker, natively, …)?
Docker
What’s your browser and operating system?
Linux version 4.4.0-139-generic ([email protected] ) (gcc version 5.4.0 20160609 (Ubuntu 5.4.0-6ubuntu1~16.04.10) ) #165 -Ubuntu SMP Wed Oct 24 10:58:50 UTC 2018
What is the problem?
show as https://docs.opendronemap.org/using.html
in native
python run.py --images </path/to/images> [arguments]
and add ‘–dem’ ‘–dsm’ in arguments could have results
but how to output dem/dsm results in docker?
What should be the expected behavior?
Such as
sudo docker run -it --rm
-v $(pwd)/images:/code/images
-v $(pwd)/odm_meshing:/code/odm_meshing
-v $(pwd)/odm_orthophoto:/code/odm_orthophoto
-v $(pwd)/odm_georeferencing:/code/odm_georeferencing
-v $(pwd)/odm_texturing:/code/odm_texturing
-v $(pwd)/opensfm:/code/opensfm
-v $(pwd)/pmvs:/code/pmvs
opendronemap/opendronemap
How to insert dem&dsm command in docker command
garlac
25 January 2019 09:14
2
ODM store dsm and dtm in a folder named odm_dem.
So you can map that docker folder to native directory to access dsm and dtm’s.
eg: add - -v “$(pwd)/odm_dem:/code/odm_dem” \ in below command and pass --dsm argument
docker run -it --rm \
-v "$(pwd)/images:/code/images" \
-v "$(pwd)/odm_georeferencing:/code/odm_georeferencing" \
-v "$(pwd)/odm_meshing:/code/odm_meshing" \
-v "$(pwd)/odm_orthophoto:/code/odm_orthophoto" \
-v "$(pwd)/odm_texturing:/code/odm_texturing" \
-v "$(pwd)/opensfm:/code/opensfm" \
opendronemap/odm --dsm
pyy
29 January 2019 03:42
3
Thank you !!!
Output ‘dsm’ result worked.
But ‘dem’ is recently not able? Right?
garlac
30 January 2019 07:06
4
You can get dsm(Digital Surface Model) and dtm(Digital Terrain Model).
For dsm add “–dsm”, for dtm add ‘–dtm’ arguments.
I think dem stands for Digital Elevation model and both dsm and dtm come under dem’s?
Correct. The dem settings are global settings (e.g. resolution) for the elevation products (digital terrain and digital surface models).
vale
6 February 2019 12:04
6
Running the command:
docker run -it --rm -v “$(pwd)/images:/code/images” -v “$(pwd)/odm_georeferencing:/code/odm_georeferencing” -v “$(pwd)/odm_meshing:/code/odm_meshing” -v “$(pwd)/odm_orthophoto:/code/odm_orthophoto” -v “$(pwd)/odm_texturing:/code/odm_texturing” -v “$(pwd)/opensfm:/code/opensfm” opendronemap/odm --dsm --dtm
I should get a folder called dsm and dtm with the results for the elevation models, correct?
There was so error message, but also no dsm and dtm.
Where can I find the logs to try to find what happened?
Apologies if these questions are newbie questions…
Regards,
António
garlac
8 February 2019 17:13
7
U need to map the another folder :
