How to improve the quality of an ortophoto?
Hi!
I’m new here,this is the first time i’m using WebODM! I’m very excited about the possibility to create my 3D models with a cloud and opensource software but my first results ARE NOT good when i compare it with the ones that i can get from other commercial softwares. I think the problem could be related to some wrong setting or something like that!
Can anyone help me?
In this link you can find the ortophoto about a moto crash done with WebODM and a folder with all the original images and a good ortophoto.
My goal is to obtain the same results with WebODM.
Thank you!
Interesting use case, my only recommendation is to turn on --use-3dmesh, --use-opensfm-dense and --opensfm-depthmap-method BRUTE_FORCE.
After that, you might want to try undistorting the images manually before feeding them in WebODM. Other software is probably handling the undistortion better, so lowering the “fish-eye” effect before processing could lead to better results.
Thank you very much Piero!
now i’m trying with your settings, thanks for your help!
