Hello Forum
I would like to get more information about at what stage my current project is. The last message in the Web-Dashboard Log-Field is from hours ago:
2022-05-01 14:28:49,545 INFO: -------------------------------------------------------
2022-05-01 14:28:49,552 INFO: DJI_0118_QW90wbu.JPG resection inliers: 124 / 141
2022-05-01 14:28:49,556 INFO: Adding DJI_0118_QW90wbu.JPG to the reconstruction
2022-05-01 14:28:50,535 INFO: -------------------------------------------------------
2022-05-01 14:28:50,541 INFO: DJI_0119_rhig42E.JPG resection inliers: 175 / 203
2022-05-01 14:28:50,545 INFO: Adding DJI_0119_rhig42E.JPG to the reconstruction
I am a little surprised that the last message doesn’t mention anything about a finished task or a newly initiated task. But I assume that’s the way it is.
So far everthing indicates that the node is still processing, but it probably run out of RAM and is swapping to the M2 drive. (CPU usage at about 20% with spikes of 100%, M2 drive is working non-stop and free space is decreasing (will probably run out of free space before project can finish))
I already logged into the docker container (webodm) with this guide but I couldn’t find anything that indicates at what stage the processing is.
Could somebody point me into the right direction to figgure out at what stage the processing is?
btw. I’m not in a hurry nor do I worry. I just try to understand it better in order to estimate better how long projects will take to process with certain settings.
