The images were collected with very intense sun. How to fix sectors that are very clear?
You can try to use a tool to pre-process the images, but if they are JPEG you will not have sufficient radiometric resolution in the 8-bit lossy-compressed files. If any channel clipped, it clipped, and you can’t recover.
DNG (or other RAW formats) and TIFF have more latitude for recovery, but there is still no magic if the sensor clipped the input, unfortunately.
Thanks. Do you indicate some pre-processing software?
I’ve been really enjoying XNConvert (free, cross-platform and portable processing profiles):
Quite simplistic, but does what is needed easily, has robust options, and works quickly enough for my taste.
