Hello ,
I’m trying tu use the plant health in Webodm. I released my WebODM but i dont know how can i use it and I dont see anywhere in the interface the plant health feature.
I need a help for this.
Regards
Hello ,
Regards
Hi ,
thank you for helping me. I dont know if there is for my version or no but i just have this menu. In where can in this menu can i see the plant health?
Regards
Make sure you are running the latest version (1.3.2), check from the “Diagnostic” panel.
Ok then navigate to the map viewer and click the “Plant Health” button from the top right corner.
Thank you verry much. I selected some images and runt it before navigate to the map viewer. It works now.
But why I dont have the others options to select others algorithms?
Regards
So one comment : in the below image , this link does not work. If it’s possible to fix it
Regards
