Does anyone have an idea how long this task should take to complete? It’s been going for about 45 hours straight. No error messages. Overall system CPU usage at 4% and RAM usage at 94%,
Docker resources settings: max CPU’s 3; RAM 48GB; the rest are all the default values.
Dataset from area: approximately 2.2 hectares of mostly flat (slight fall) property, some trees along two edges and a berm along one edge.
Task: 171 photos at 12MP each, GCP list (13x GCP’s)
Options: pc-classify: true, orthophoto-png: true, min-num-features: 12000, smrf-slope: 0.05, rerun-from: dataset, use-3dmesh: true, orthophoto-resolution: 2.2, dtm: true, dem-resolution: 2.2, mesh-size: 2000000, texturing-keep-unseen-faces: true, debug: true, pc-rectify: true, pc-ept: true, crop: 0, pc-las: true, dsm: true, max-concurrency: 3, texturing-tone-mapping: gamma, dem-euclidean-map: true, pc-csv: true, verbose: true, use-hybrid-bundle-adjustment: true
DropBox link to Task Output TXT file
Thanks in advance!
*** EDIT ***
DropBox link to Console TXT file, probably of more use than the Output TXT file above.
