MacStudio, M1 (10C) CPU, 64 GB memory - running Ventura.
The attached photo is my screen trying to do something (anything) with Docker.
How many hours do you let this go before you call it?
I have quit out of it and Web ODM, shut down the computer, re started and re- opened and I get the message that “Docker Desktop Stopped “on the screen, message from WebODM that Docker has been installed but is not communicating and to close and reopen docker directly and when I do I get the same message. I have closed out, shut down,re-started, several times. I have lost every file that I successfully loaded because I have also done the Clean/Purge as well as the Reset to factory defaults multiple times in an attempt to get it to work again.
So my question for you is: how much is enough time?
https://www.dropbox.com/s/yzl60xac1c6x4ft/IMG_4443.heic?dl=0
