How does ODMWeb calculate the volume
Hi all !
I just arrive here in this forum
I use a Macvic 2 Pro
I want to use it to compare volume before and after earthwork.
I mean : I work in a land, I do my fly and i save my pictures. After there are some earthwork that change de topography of the land. I do the same plan of fly again.
I would like to compare the difference between before and after the earthwork.
I’ve seen on ODMWeb that I can mesure the volume.
I’d would like to know how the volume is calculated. Is it from the lowest point that ODM calcul the volume ?
Is it possible to put compare the two flys on the same project : to calculate the difference between before and after the earthwork ?
Thanks so much for your help
Pierre
The GRASS script that computes volume is: https://github.com/OpenDroneMap/WebODM/blob/master/plugins/measure/calc_volume.grass
Please explain how to use the script. How to run it to compare
Hi, did you figure out how to compare the volumes from 2 fly byes in the same project?
Hi @pierotofy,
This link does not exist anymore. Can you provide the present link? And provide more details on how it is can be used separately only to measure volume?
Thanks,
darkl1ght
https://github.com/OpenDroneMap/WebODM/blob/master/plugins/measure/calc_volume.py
