Ok newbie here, I’ve run several missions including one today which was flown on a grid pattern, and I’m happy with the 2D https://maphub.online/?ll=51.61172%2C-0.70600&z=18 However the 3D is full of holes as can be seen in this image
Ok I’ll have a play, what if i was to take another set of photos say 100 foot lower and with the gimbal maybe at -75 and included them in the dataset, would that help, just curious, thanks for your help
Yes, that should absolutely help. Same if you can hit maybe -60 and -45 or so in addition to -75, if you really want/need the sides of objects. It should give you a much more complete reconstruction.
Awesome! Glad you’re getting closer to what you want
And help is what I’m here for (and also to learn from everyone else :D), so no worries.
I wouldn’t get rid of this dataset yet, either. We have some big changes landing in and just before ODM v2.8.6 that might help improve things further. But yeah, absolutely (if you can) grab those other “layers” of your flight plan with the different gimbal angles.
Ok, been playing around a bit more and flew a mission with 2 layers, one at 285 feet and -90 gimbal, then the second layer at 185 feet and -75 gimbal, I then ran the resulting dataset twice:
