How can I create a 5-band multispectral image in WebODM?
When I use P4 Multispectral and composite the captured image with WebODM, the multispectral bands that should have been 5 bands are now 4 bands. The setting is set to multisupectral and synthesized. Is there any solution to this problem?
Where are you verifying the band count in? A geospatial tool like QGIS/GDAL?
Are you able to share an example output and your processing parameters?
Thanks for responding.
I used GDAL for my band count. Here is the result of the output.
Driver: GTiff/GeoTIFF
Files: 20220708org.tif
Size is 13865, 12916
Coordinate System is:
GEOGCRS[“WGS 84”,
DATUM[“World Geodetic System 1984”,
ELLIPSOID[“WGS 84”,6378137,298.257223563,
LENGTHUNIT[“metre”,1]]],
PRIMEM[“Greenwich”,0,
ANGLEUNIT[“degree”,0.0174532925199433]],
CS[ellipsoidal,2],
AXIS[“geodetic latitude (Lat)”,north,
ORDER[1],
AXIS[“geodetic longitude (Lon)”,east,
ORDER[2],
ID[“EPSG”,4326]]
Data axis to CRS axis mapping: 2,1
Origin = (140.208222893572554,36.034066164428872)
Pixel Size = (0.000000499137496,-0.000000499137496)
Metadata:
AREA_OR_POINT=Area
Image Structure Metadata:
COMPRESSION=JPEG
INTERLEAVE=PIXEL
Corner Coordinates:
Upper Left ( 140.2082229, 36.0340662) (140d12’29.60"E, 36d 2’ 2.64"N)
Lower Left ( 140.2082229, 36.0276193) (140d12’29.60"E, 36d 1’39.43"N)
Upper Right ( 140.2151434, 36.0340662) (140d12’54.52"E, 36d 2’ 2.64"N)
Lower Right ( 140.2151434, 36.0276193) (140d12’54.52"E, 36d 1’39.43"N)
Center ( 140.2116832, 36.0308427) (140d12’42.06"E, 36d 1’51.03"N)
Band 1 Block=13865x16 Type=Byte, ColorInterp=Red
Mask Flags: PER_DATASET ALPHA
Band 2 Block=13865x16 Type=Byte, ColorInterp=Green
Band 3 Block=13865x16 Type=Byte, ColorInterp=Blue
Band 4 Block=13865x16 Type=Byte, ColorInterp=Alpha
Can you provide the input data and your processing parameters? Something doesn’t make sense here, unfortunately.
Hello, Mr.Saijin.
Sorry for the delay in getting back to you.
I made some adjustments based on other questions on my end and it worked.
It was due to the fact that radiometric caribration was not enabled.
Thanks for your help and I will try to get it fixed. Thank you very much.
Glad you got it sorted!
Happy processing!
Please feel free to show off in #the-showroom !
