High quality stitched map
Dear forum members,
Apoligies if I waste your time with really dumb newbe questions.
I flew a mission with my Autel EVO II. It took 1110 pictures with about 80% overlap of a certain buildingsite.
I uploaded those in WebODM. My computer had a really hard time, but after over 12 hours it completed the job.
What I cant seem to find is a high quality map composed of the stitched photos.
Just a really sharp 2D panorama-like map.
Or is this not what WebODM was build for?
And if not… Any suggestions what software I could use for this purpose?
Thanks for your time.
Best regards,
Frans
your ortho tif is a stitched image.
bring that into GIS or Google Earth and resave in jpg if you need that.
(screen capture and crop is a dirty way to do it as well).
there is a setting in WebODM to export the generated ortho to png, did you check that in the custom menu?
you may be able to reprocess for that alone.
Thank yoy for your quick reply.
Can you help me to find this png option?
Is it a plugin?
under options (below “processing node”)
click the “edit” button directly, on the far right…the processing options are in alphabetical order…
34 options down you will see
“ortho-png”…click to enable a png generation when processing completes…
it will be in the all zip file…
dfd
click on the edit button, scroll down 34 items…they are alphabetic…get to ortho-png and check enable, then SAVE!
You have to check this EVERY TIME, if you want a png…its not a default in any of the standard choices…
dfd
Found it.
Thanks again for your time and swift replies.
