I recently bought WEBDOM to create orthophotos. I did the first one without any problems, from then on, all the orthophotos came out missing or distorted images. A curiosity is that the program is taking half the time to render the images. Can anyone help?
Images follow
Need more information to help.
The first thing would to be sure your dataset is proper. do images have enough overlap? no motion blur? blurry images? also what parameters did you use to process the dataset?
