Hello to all,
I need help with the installation of WebODM. Indeed after installing the docker on my computer, I can’t manage to satisfy the step consisting in allocating space to the virtual machine which will run the docker on the computer. It seems to me that in order to do this I must have a WSL container because the one I have is not of a recent version (this is the error message I get when opening the Docker).
I would like to have some guidelines to solve this problem in order to finally finish the steps required to install WebODM.
Thanks in advance.
Follow the install instructions here for Windows first:
Then ensure you are using the most current release of Windows 10, fully upgraded, and your WSL2 kernel should be automatically updated and handled via Windows Update.
