Help a newbie with how to process 3000-5000 images?
Hi Guys,
I am using WEBODM lightning with great results to process image sets of up to 1500 images. Its been working great!
My question is that I now have a image dataset from a P4P v2 with 3200 images, and even the upgrade to business is limited to only 3000 images. So how can I process this with Webodm Lightning?
In the past I have been using DDeploy in a previous business to process my datasets up to 8000 images from P4Pv2. But its just miles out of my price range while I am starting a very small business.
Is there any way at all to get a lightning monthly account that could do up to 5000 images?
Im happy to pay/support the project a bit more for the months where I have the bigger datasets, and I can build that into the client costs so long as its reasonable.
Most of my datasets are less than 3000 images, but maybe 4-6 times a year it would be between 3000-8000 images. I would really like to stay with lightning processing if I can?
I am hesitant to try local processing as my Laptop is only i7 with 32gb ram and geforce card, and am not sure this will process ok with a local webodm install and 5000 or more images?
I am totally happy to buy/support the local webodm setup if this might work on my hardware, but I dont really want to tie up my laptop for long periods if I can avoid it?
Are there any people running services with ODM or DroneDeploy that can process the bigger datasets for me, on the odd time that I do get them?
Brian
We do not have any Service Tiers above Business for Lighting, so currently 3,000 image Tasks are our maximum.
32GB RAM will be insufficient for 3,000-8,000 image Tasks, figure 128GB at a bare minimum (what we have for Lightning nodes).
Some folks self-host WebODM on things like Azure, Amazon Web Services, Google Cloud Platform, DigitalOcean, Hetzner, etc. to be able to size their VMs as needed.
Thanks Saijin,
Do you think 32GB RAM will do 3200 images?
What about if I went to 64 GB RAM?
The amount of memory required for a run has more variables than just number of images. I’ve posted a few threads where I set up Grafana and Prometheus to attempt to identify the impact of some of the options available when starting a job, and it was harder than it sounds.
My current theory is that given a static configuration (i.e., ultra/ultra but no other changes) the factors with the largest impact are number of images and something accounting for photo density/overlap/etc. but I have not had time to refine that theory. Fingers crossed that others with more spare time can come up with additional arguments and data to support them!
