Having issues to generate DTM with pc2dem...(WebODM - Docker)
I’ve been able to use this code via Docker and CMD from Lidar cloud points for the défault DSM but not for the DTM :
No error returned but de values par pixel aren’t correct :
Any idea of what’s causing this issue?
(Using Windows 10 with Docker and libraries correctly installed)
Thanks in advance
Perhaps the raster statistics aren’t being written to the file.
Can you adjust the symbology in QGIS to use Calculated instead of Estimated values, and/or possibly run the Raster Information tool from GDAL within QGIS to force update/computation of the proper values:
It doesn’t work. Value not valid…
:frowning:
What are the exact parameters you’re passing to pc2dem?
In CMD (administrator) :
Here the results :
[INFO] running pdal info --summary “/input/*********************************.laz” > “/tmp/tmpeskycu6v.json”
[INFO] Point cloud bounds are [minx: 464000, maxx: 464999.999] [miny: 6408000, maxy: 6408999.999]
[INFO] DEM resolution is (20000, 20000), max tile size is 4096, will split DEM generation into 25 tiles
[INFO] Generating /input/dtm_r0.1_x0_y0.tif (idw, radius: 0.1, resolution: 0.05)
[INFO] Generating /input/dtm_r0.1_x0_y1.tif (idw, radius: 0.1, resolution: 0.05)
[INFO] Generating /input/dtm_r0.1_x0_y2.tif (idw, radius: 0.1, resolution: 0.05)
[INFO] Generating /input/dtm_r0.1_x0_y3.tif (idw, radius: 0.1, resolution: 0.05)
[INFO] Generating /input/dtm_r0.1_x0_y4.tif (idw, radius: 0.1, resolution: 0.05)
[INFO] Generating /input/dtm_r0.1_x1_y0.tif (idw, radius: 0.1, resolution: 0.05)
[INFO] Generating /input/dtm_r0.1_x1_y1.tif (idw, radius: 0.1, resolution: 0.05)
[INFO] Generating /input/dtm_r0.1_x1_y2.tif (idw, radius: 0.1, resolution: 0.05)
[INFO] Pipeline file: /tmp/tmpw9yx7ajs.json
[INFO] Pipeline file: /tmp/tmpz28ig1kf.json
[INFO] Pipeline file: /tmp/tmp1srr2z1l.json
[INFO] Pipeline file: /tmp/tmp8q39f3pr.json
[INFO] Pipeline file: /tmp/tmp3_8aufaq.json
[INFO] Pipeline file: /tmp/tmp79voglza.json
[INFO] Pipeline file: /tmp/tmpk_bwbxcx.json
[INFO] Pipeline file: /tmp/tmpop26ubj2.json
[INFO] running pdal pipeline -i /tmp/tmpw9yx7ajs.json
[INFO] running pdal pipeline -i /tmp/tmpz28ig1kf.json
[INFO] running pdal pipeline -i /tmp/tmp1srr2z1l.json
[INFO] running pdal pipeline -i /tmp/tmp8q39f3pr.json
[INFO] running pdal pipeline -i /tmp/tmp3_8aufaq.json
[INFO] running pdal pipeline -i /tmp/tmp79voglza.json
[INFO] running pdal pipeline -i /tmp/tmpk_bwbxcx.json
[INFO] running pdal pipeline -i /tmp/tmpop26ubj2.json
[INFO] Generating /input/dtm_r0.1_x1_y3.tif (idw, radius: 0.1, resolution: 0.05)
[INFO] Pipeline file: /tmp/tmp1ww0f5y6.json
[INFO] running pdal pipeline -i /tmp/tmp1ww0f5y6.json
[INFO] Generating /input/dtm_r0.1_x1_y4.tif (idw, radius: 0.1, resolution: 0.05)
[INFO] Pipeline file: /tmp/tmp_75i5k_d.json
[INFO] running pdal pipeline -i /tmp/tmp_75i5k_d.json
[INFO] Generating /input/dtm_r0.1_x2_y0.tif (idw, radius: 0.1, resolution: 0.05)
[INFO] Pipeline file: /tmp/tmp0qr3hyfb.json
[INFO] running pdal pipeline -i /tmp/tmp0qr3hyfb.json
[INFO] Generating /input/dtm_r0.1_x2_y1.tif (idw, radius: 0.1, resolution: 0.05)
[INFO] Pipeline file: /tmp/tmp6r9toclu.json
[INFO] running pdal pipeline -i /tmp/tmp6r9toclu.json
[INFO] Generating /input/dtm_r0.1_x2_y2.tif (idw, radius: 0.1, resolution: 0.05)
[INFO] Pipeline file: /tmp/tmpzin46ow3.json
[INFO] running pdal pipeline -i /tmp/tmpzin46ow3.json
[INFO] Generating /input/dtm_r0.1_x2_y3.tif (idw, radius: 0.1, resolution: 0.05)
[INFO] Pipeline file: /tmp/tmpbzdp2v_r.json
[INFO] running pdal pipeline -i /tmp/tmpbzdp2v_r.json
[INFO] Generating /input/dtm_r0.1_x2_y4.tif (idw, radius: 0.1, resolution: 0.05)
[INFO] Pipeline file: /tmp/tmpnm7fkbf9.json
[INFO] running pdal pipeline -i /tmp/tmpnm7fkbf9.json
[INFO] Generating /input/dtm_r0.1_x3_y0.tif (idw, radius: 0.1, resolution: 0.05)
[INFO] Pipeline file: /tmp/tmpo95abpw3.json
[INFO] running pdal pipeline -i /tmp/tmpo95abpw3.json
[INFO] Generating /input/dtm_r0.1_x3_y1.tif (idw, radius: 0.1, resolution: 0.05)
[INFO] Pipeline file: /tmp/tmp9wkt5viw.json
[INFO] running pdal pipeline -i /tmp/tmp9wkt5viw.json
[INFO] Generating /input/dtm_r0.1_x3_y2.tif (idw, radius: 0.1, resolution: 0.05)
[INFO] Pipeline file: /tmp/tmpk65wy8k_.json
[INFO] running pdal pipeline -i /tmp/tmpk65wy8k_.json
[INFO] Generating /input/dtm_r0.1_x3_y3.tif (idw, radius: 0.1, resolution: 0.05)
[INFO] Pipeline file: /tmp/tmphqfwjn1m.json
[INFO] running pdal pipeline -i /tmp/tmphqfwjn1m.json
[INFO] Generating /input/dtm_r0.1_x3_y4.tif (idw, radius: 0.1, resolution: 0.05)
[INFO] Pipeline file: /tmp/tmp3l_m5q5a.json
[INFO] running pdal pipeline -i /tmp/tmp3l_m5q5a.json
[INFO] Generating /input/dtm_r0.1_x4_y0.tif (idw, radius: 0.1, resolution: 0.05)
[INFO] Pipeline file: /tmp/tmp8eu4_n_n.json
[INFO] running pdal pipeline -i /tmp/tmp8eu4_n_n.json
[INFO] Generating /input/dtm_r0.1_x4_y1.tif (idw, radius: 0.1, resolution: 0.05)
[INFO] Pipeline file: /tmp/tmp0x4avvkt.json
[INFO] running pdal pipeline -i /tmp/tmp0x4avvkt.json
[INFO] Generating /input/dtm_r0.1_x4_y2.tif (idw, radius: 0.1, resolution: 0.05)
[INFO] Pipeline file: /tmp/tmpohrt88nl.json
[INFO] running pdal pipeline -i /tmp/tmpohrt88nl.json
[INFO] Generating /input/dtm_r0.1_x4_y3.tif (idw, radius: 0.1, resolution: 0.05)
[INFO] Pipeline file: /tmp/tmpslbjb39u.json
[INFO] running pdal pipeline -i /tmp/tmpslbjb39u.json
[INFO] Generating /input/dtm_r0.1_x4_y4.tif (idw, radius: 0.1, resolution: 0.05)
[INFO] Pipeline file: /tmp/tmpodynau8z.json
[INFO] running pdal pipeline -i /tmp/tmpodynau8z.json
[INFO] Generating /input/dtm_r0.05_x0_y0.tif (idw, radius: 0.05, resolution: 0.05)
[INFO] Pipeline file: /tmp/tmpbdkcdy9f.json
[INFO] running pdal pipeline -i /tmp/tmpbdkcdy9f.json
[INFO] Generating /input/dtm_r0.05_x0_y1.tif (idw, radius: 0.05, resolution: 0.05)
[INFO] Pipeline file: /tmp/tmp9792qduk.json
[INFO] running pdal pipeline -i /tmp/tmp9792qduk.json
[INFO] Generating /input/dtm_r0.05_x0_y2.tif (idw, radius: 0.05, resolution: 0.05)
[INFO] Pipeline file: /tmp/tmp8d9fbwa5.json
[INFO] running pdal pipeline -i /tmp/tmp8d9fbwa5.json
[INFO] Generating /input/dtm_r0.05_x0_y3.tif (idw, radius: 0.05, resolution: 0.05)
[INFO] Pipeline file: /tmp/tmp4t33g6dk.json
[INFO] running pdal pipeline -i /tmp/tmp4t33g6dk.json
[INFO] Generating /input/dtm_r0.05_x0_y4.tif (idw, radius: 0.05, resolution: 0.05)
[INFO] Pipeline file: /tmp/tmpylmh3gh5.json
[INFO] running pdal pipeline -i /tmp/tmpylmh3gh5.json
[INFO] Generating /input/dtm_r0.05_x1_y0.tif (idw, radius: 0.05, resolution: 0.05)
[INFO] Pipeline file: /tmp/tmp4lo6j9v7.json
[INFO] running pdal pipeline -i /tmp/tmp4lo6j9v7.json
[INFO] Generating /input/dtm_r0.05_x1_y1.tif (idw, radius: 0.05, resolution: 0.05)
[INFO] Pipeline file: /tmp/tmpa75z7050.json
[INFO] running pdal pipeline -i /tmp/tmpa75z7050.json
[INFO] Generating /input/dtm_r0.05_x1_y2.tif (idw, radius: 0.05, resolution: 0.05)
[INFO] Pipeline file: /tmp/tmpri7yd4m5.json
[INFO] running pdal pipeline -i /tmp/tmpri7yd4m5.json
[INFO] Generating /input/dtm_r0.05_x1_y3.tif (idw, radius: 0.05, resolution: 0.05)
[INFO] Pipeline file: /tmp/tmpxjriatmx.json
[INFO] running pdal pipeline -i /tmp/tmpxjriatmx.json
[INFO] Generating /input/dtm_r0.05_x1_y4.tif (idw, radius: 0.05, resolution: 0.05)
[INFO] Pipeline file: /tmp/tmpfn444fa4.json
[INFO] running pdal pipeline -i /tmp/tmpfn444fa4.json
[INFO] Generating /input/dtm_r0.05_x2_y0.tif (idw, radius: 0.05, resolution: 0.05)
[INFO] Pipeline file: /tmp/tmpjce17si_.json
[INFO] running pdal pipeline -i /tmp/tmpjce17si_.json
[INFO] Generating /input/dtm_r0.05_x2_y1.tif (idw, radius: 0.05, resolution: 0.05)
[INFO] Pipeline file: /tmp/tmpw00p8ebv.json
[INFO] running pdal pipeline -i /tmp/tmpw00p8ebv.json
[INFO] Generating /input/dtm_r0.05_x2_y2.tif (idw, radius: 0.05, resolution: 0.05)
[INFO] Pipeline file: /tmp/tmpqz7g2_pi.json
[INFO] running pdal pipeline -i /tmp/tmpqz7g2_pi.json
[INFO] Generating /input/dtm_r0.05_x2_y3.tif (idw, radius: 0.05, resolution: 0.05)
[INFO] Pipeline file: /tmp/tmpawqplveu.json
[INFO] running pdal pipeline -i /tmp/tmpawqplveu.json
[INFO] Generating /input/dtm_r0.05_x2_y4.tif (idw, radius: 0.05, resolution: 0.05)
[INFO] Pipeline file: /tmp/tmp3266lmxn.json
[INFO] running pdal pipeline -i /tmp/tmp3266lmxn.json
[INFO] Generating /input/dtm_r0.05_x3_y0.tif (idw, radius: 0.05, resolution: 0.05)
[INFO] Pipeline file: /tmp/tmpm9wzak7a.json
[INFO] running pdal pipeline -i /tmp/tmpm9wzak7a.json
[INFO] Generating /input/dtm_r0.05_x3_y1.tif (idw, radius: 0.05, resolution: 0.05)
[INFO] Pipeline file: /tmp/tmpq1r37sz8.json
[INFO] running pdal pipeline -i /tmp/tmpq1r37sz8.json
[INFO] Generating /input/dtm_r0.05_x3_y2.tif (idw, radius: 0.05, resolution: 0.05)
[INFO] Pipeline file: /tmp/tmpqwnv4ior.json
[INFO] running pdal pipeline -i /tmp/tmpqwnv4ior.json
[INFO] Generating /input/dtm_r0.05_x3_y3.tif (idw, radius: 0.05, resolution: 0.05)
[INFO] Pipeline file: /tmp/tmpk7u9xgz7.json
[INFO] running pdal pipeline -i /tmp/tmpk7u9xgz7.json
[INFO] Generating /input/dtm_r0.05_x3_y4.tif (idw, radius: 0.05, resolution: 0.05)
[INFO] Pipeline file: /tmp/tmphfqpqj3f.json
[INFO] running pdal pipeline -i /tmp/tmphfqpqj3f.json
[INFO] Generating /input/dtm_r0.05_x4_y0.tif (idw, radius: 0.05, resolution: 0.05)
[INFO] Pipeline file: /tmp/tmph5k4gadj.json
[INFO] running pdal pipeline -i /tmp/tmph5k4gadj.json
[INFO] Generating /input/dtm_r0.05_x4_y1.tif (idw, radius: 0.05, resolution: 0.05)
[INFO] Pipeline file: /tmp/tmpdzg7azm7.json
[INFO] running pdal pipeline -i /tmp/tmpdzg7azm7.json
[INFO] Generating /input/dtm_r0.05_x4_y2.tif (idw, radius: 0.05, resolution: 0.05)
[INFO] Pipeline file: /tmp/tmp7u225al8.json
[INFO] running pdal pipeline -i /tmp/tmp7u225al8.json
[INFO] Generating /input/dtm_r0.05_x4_y3.tif (idw, radius: 0.05, resolution: 0.05)
[INFO] Pipeline file: /tmp/tmpwtwky5bk.json
[INFO] running pdal pipeline -i /tmp/tmpwtwky5bk.json
[INFO] Generating /input/dtm_r0.05_x4_y4.tif (idw, radius: 0.05, resolution: 0.05)
[INFO] Pipeline file: /tmp/tmpla_6n6ei.json
[INFO] running pdal pipeline -i /tmp/tmpla_6n6ei.json
[INFO] Generating /input/dtm_r0.025_x0_y0.tif (idw, radius: 0.025, resolution: 0.05)
[INFO] Pipeline file: /tmp/tmptsxwpb4c.json
[INFO] running pdal pipeline -i /tmp/tmptsxwpb4c.json
[INFO] Generating /input/dtm_r0.025_x0_y1.tif (idw, radius: 0.025, resolution: 0.05)
[INFO] Pipeline file: /tmp/tmpxc46mb16.json
[INFO] running pdal pipeline -i /tmp/tmpxc46mb16.json
[INFO] Generating /input/dtm_r0.025_x0_y2.tif (idw, radius: 0.025, resolution: 0.05)
[INFO] Pipeline file: /tmp/tmp7m095ky5.json
[INFO] running pdal pipeline -i /tmp/tmp7m095ky5.json
[INFO] Generating /input/dtm_r0.025_x0_y3.tif (idw, radius: 0.025, resolution: 0.05)
[INFO] Pipeline file: /tmp/tmpyenjljow.json
[INFO] running pdal pipeline -i /tmp/tmpyenjljow.json
[INFO] Generating /input/dtm_r0.025_x0_y4.tif (idw, radius: 0.025, resolution: 0.05)
[INFO] Pipeline file: /tmp/tmpvu0vll1o.json
[INFO] running pdal pipeline -i /tmp/tmpvu0vll1o.json
[INFO] Generating /input/dtm_r0.025_x1_y0.tif (idw, radius: 0.025, resolution: 0.05)
[INFO] Pipeline file: /tmp/tmpi8z_f01t.json
[INFO] running pdal pipeline -i /tmp/tmpi8z_f01t.json
[INFO] Generating /input/dtm_r0.025_x1_y1.tif (idw, radius: 0.025, resolution: 0.05)
[INFO] Pipeline file: /tmp/tmpiufkiujp.json
[INFO] running pdal pipeline -i /tmp/tmpiufkiujp.json
[INFO] Generating /input/dtm_r0.025_x1_y2.tif (idw, radius: 0.025, resolution: 0.05)
[INFO] Pipeline file: /tmp/tmpfdstbftd.json
[INFO] running pdal pipeline -i /tmp/tmpfdstbftd.json
[INFO] Generating /input/dtm_r0.025_x1_y3.tif (idw, radius: 0.025, resolution: 0.05)
[INFO] Pipeline file: /tmp/tmpn1vx1cu6.json
[INFO] running pdal pipeline -i /tmp/tmpn1vx1cu6.json
[INFO] Generating /input/dtm_r0.025_x1_y4.tif (idw, radius: 0.025, resolution: 0.05)
[INFO] Pipeline file: /tmp/tmpeyi1abxk.json
[INFO] running pdal pipeline -i /tmp/tmpeyi1abxk.json
[INFO] Generating /input/dtm_r0.025_x2_y0.tif (idw, radius: 0.025, resolution: 0.05)
[INFO] Pipeline file: /tmp/tmp9d0m9fjn.json
[INFO] running pdal pipeline -i /tmp/tmp9d0m9fjn.json
[INFO] Generating /input/dtm_r0.025_x2_y1.tif (idw, radius: 0.025, resolution: 0.05)
[INFO] Pipeline file: /tmp/tmp5edakp27.json
[INFO] running pdal pipeline -i /tmp/tmp5edakp27.json
[INFO] Generating /input/dtm_r0.025_x2_y2.tif (idw, radius: 0.025, resolution: 0.05)
[INFO] Pipeline file: /tmp/tmpzeyonmf3.json
[INFO] running pdal pipeline -i /tmp/tmpzeyonmf3.json
[INFO] Generating /input/dtm_r0.025_x2_y3.tif (idw, radius: 0.025, resolution: 0.05)
[INFO] Pipeline file: /tmp/tmp152ef70s.json
[INFO] running pdal pipeline -i /tmp/tmp152ef70s.json
[INFO] Generating /input/dtm_r0.025_x2_y4.tif (idw, radius: 0.025, resolution: 0.05)
[INFO] Pipeline file: /tmp/tmpmpms4zhw.json
[INFO] running pdal pipeline -i /tmp/tmpmpms4zhw.json
[INFO] Generating /input/dtm_r0.025_x3_y0.tif (idw, radius: 0.025, resolution: 0.05)
[INFO] Pipeline file: /tmp/tmponb2omaz.json
[INFO] running pdal pipeline -i /tmp/tmponb2omaz.json
[INFO] Generating /input/dtm_r0.025_x3_y1.tif (idw, radius: 0.025, resolution: 0.05)
[INFO] Pipeline file: /tmp/tmpz5w2h_me.json
[INFO] running pdal pipeline -i /tmp/tmpz5w2h_me.json
[INFO] Generating /input/dtm_r0.025_x3_y2.tif (idw, radius: 0.025, resolution: 0.05)
[INFO] Pipeline file: /tmp/tmpp52iag1k.json
[INFO] running pdal pipeline -i /tmp/tmpp52iag1k.json
[INFO] Generating /input/dtm_r0.025_x3_y3.tif (idw, radius: 0.025, resolution: 0.05)
[INFO] Pipeline file: /tmp/tmpq7inbv3q.json
[INFO] running pdal pipeline -i /tmp/tmpq7inbv3q.json
[INFO] Generating /input/dtm_r0.025_x3_y4.tif (idw, radius: 0.025, resolution: 0.05)
[INFO] Generating /input/dtm_r0.025_x4_y0.tif (idw, radius: 0.025, resolution: 0.05)
[INFO] Pipeline file: /tmp/tmpzd7rw50l.json
[INFO] running pdal pipeline -i /tmp/tmpzd7rw50l.json
[INFO] Pipeline file: /tmp/tmpkii3pgac.json
[INFO] running pdal pipeline -i /tmp/tmpkii3pgac.json
[INFO] Generating /input/dtm_r0.025_x4_y1.tif (idw, radius: 0.025, resolution: 0.05)
[INFO] Pipeline file: /tmp/tmpc7vl5t1_.json
[INFO] running pdal pipeline -i /tmp/tmpc7vl5t1_.json
[INFO] Generating /input/dtm_r0.025_x4_y2.tif (idw, radius: 0.025, resolution: 0.05)
[INFO] Pipeline file: /tmp/tmpferx08xe.json
[INFO] running pdal pipeline -i /tmp/tmpferx08xe.json
[INFO] Generating /input/dtm_r0.025_x4_y3.tif (idw, radius: 0.025, resolution: 0.05)
[INFO] Pipeline file: /tmp/tmptt8_0dca.json
[INFO] running pdal pipeline -i /tmp/tmptt8_0dca.json
[INFO] Generating /input/dtm_r0.025_x4_y4.tif (idw, radius: 0.025, resolution: 0.05)
[INFO] Pipeline file: /tmp/tmpccwmeor_.json
[INFO] running pdal pipeline -i /tmp/tmpccwmeor_.json
[INFO] running gdalbuildvrt -input_file_list “/input/tiles_list.txt” “/input/tiles.vrt”
[INFO] running gdal_translate -co NUM_THREADS=8 -co BIGTIFF=IF_SAFER --config GDAL_CACHEMAX 47.15% “/input/tiles.vrt” “/input/tiles.tmp.tif”
Input file size is 20000, 20000
[INFO] running gdal_translate -co NUM_THREADS=8 -co BIGTIFF=IF_SAFER --config GDAL_CACHEMAX 47.15% -outsize 10% 0 “/input/tiles.tmp.tif” “/input/tiles.small.tif”
[INFO] running gdalbuildvrt -resolution highest -r bilinear “/input/merged.vrt” “/input/tiles.small_filled.tif” “/input/tiles.tmp.tif”
[INFO] running gdal_translate -co NUM_THREADS=8 -co TILED=YES -co BIGTIFF=IF_SAFER -co COMPRESS=DEFLATE --config GDAL_CACHEMAX 47.15% “/input/merged.vrt” “/input/tiles.tif”
[INFO] Starting smoothing…
[INFO] Smoothing iteration 1
[INFO] Completed smoothing to create /input/dtm.tif in 0:01:27.234627
[INFO] Completed dtm.tif in 0:10:03.427016
:wink:
up
:slight_smile:
