Below is the end of the log file. datasets that used to process with no issues now for some reason having issues.
my setup is webodm on a small machine with nodeodm on a more robust machine 128gb ram 128gb swap. odm version is 3.0.2. Thanks for help or suggestions.
/code/SuperBuild/install/bin/opensfm/bin/opensfm: line 12: 45156 Segmentation fault (core dumped) “$PYTHON” “$DIR”/opensfm_main.py “[email protected]”
Child returned 139
File “/code/stages/odm_app.py”, line 81, in execute
File “/code/opendm/types.py”, line 386, in run
File “/code/opendm/types.py”, line 365, in run
File “/code/stages/run_opensfm.py”, line 35, in process
File “/code/opendm/osfm.py”, line 411, in feature_matching
self.match_features(rerun)
File “/code/opendm/osfm.py”, line 416, in match_features
self.run(‘match_features’)
File “/code/opendm/osfm.py”, line 34, in run
system.run(‘“%s” %s “%s”’ %
File “/code/opendm/system.py”, line 109, in run
opendm.system.SubprocessException: Child returned 139
[ERROR] Uh oh! Processing stopped because of strange values in the reconstruction. This is often a sign that the input data has some issues or the software cannot deal with it. Have you followed best practices for data acquisition? See Flying Tips — OpenDroneMap 3.0.2 documentation
