Hanging on the zip... ortho 2D available in App's temp folder
Hi i am having trouble in getting the full output in projects over 200 images (using default setting and 16GM RAM. I see that there have been similar issues in the past by as a partial fix.
The last few line of the Task Output is:
"Postprocessing: done (•̀ᴗ•́)و!
Compressing all.zip
Uploading 1 files to S3…"
After that no progress.
A tif has been generated and reading previous work arounds there is a chance to recover it via:
WebODMLightning
resources
app
data
media
temp
(sorry first post, may have missed some info)
Am I correct in that you’re using WebODM Lightning to process your data? If so, the data are not stored on your computer, but instead are on the Lightning instance.
Sorry yes the little amount of RAM on my PC shouldn’t make a difference as it getting processed via the cloud :blush: .
Is there a workaround to improve the performance when submitting to WebODM Lightning? Perhaps breaking jobs down in to small chunks?
You could use split / merge certainly, but I don’t think you need to with that amount of data.
For decreasing time to upload, I pass my images through Caesium Image Compressor to do lossless optimization. Saves me anywhere from 5-20% file size.
As for the not finishing of pushing results to S3, that normally indicates a transient network/service issue.
It should not happen again, I don’t think.
Are you running the latest version of the WebODM Lightning app (when did you install it?) We’ve worked on a fix for something related to this about ~10 days ago.
If this happens again, can you fetch a copy of the app logs (Tools → View Logs) and attach them to this thread?
thanks, will have a look at the compressor as an additional measure.
Hi
On opening its showing version V1.1.2 and once in it says that i am using the latest version. I have run 7 similar sized projects using default settings and the last 3 have hung.
I have another (new drone, good weather ;)… and will try again via Lightning and post log if the S3 is occurs again.
I did manage to install WebODM too (as i wanted to try some of the forestry plugins, but i need to get my head around the basics first… its fun!)
Ben
Sorry please don’t take this as a moan, I am trying to understand where I am going wrong and what parameters I can control (better upload speed, using a PC to soley perform tasks in WebODM (without the Lightning).
This time the project has been hanging for around 3hrs at the
“Uploading images to processing node” at around the 75% completed stage.
I am not sure whether this hang is within the Lightning Servers OR during the upload of images from my PC to the Lightning servers.
The task is:
Created on: 01/07/2021, 09:14:46
Processing Node: Lightning (manual)
Options: dsm: true
The processing node being used is:
Hostname spark1.webodm.net
Port 443
API Version 1.5.3
Engine odm
Engine Version 2.5.7
Queue Count 0
Max Images Limit 1500
Label Lightning
Last Refreshed 0 minutes ago (1 Jul 2021, 12:02 p.m.)
Should I (can i) be editing the Options in (JSON)?
“domain”: “integer”,
“help”: “Legacy option (use --feature-quality instead). Resizes images by the largest side for feature extraction purposes only. Set to -1 to disable. This does not affect the final orthophoto resolution quality and will not resize the original images. Default: %(default)s”,
“name”: “resize-to”,
“value”: “2048”,
“type”: “int”
“domain”: [
“dataset”,
“split”,
“merge”,
“opensfm”,
“openmvs”,
“odm_filterpoints”,
“odm_meshing”,
“mvs_texturing”,
“odm_georeferencing”,
“odm_dem”,
“odm_orthophoto”,
“odm_report”
“help”: “End processing at this stage. Can be one of: %(choices)s. Default: %(default)s”,
“name”: “end-with”,
“value”: “odm_report”,
“type”: “enum”
“domain”: [
“help”: “Rerun processing from this stage. Can be one of: %(choices)s. Default: %(default)s”,
“name”: “rerun-from”,
“value”: “”,
“type”: “enum”
“help”: “Minimum number of features to extract per image. More features can be useful for finding more matches between images, potentially allowing the reconstruction of areas with little overlap or insufficient features. More features also slow down processing. Default: %(default)s”,
“name”: “min-num-features”,
“value”: “8000”,
“type”: “int”
“domain”: [
“sift”,
“hahog”
“help”: “Choose the algorithm for extracting keypoints and computing descriptors. Can be one of: %(choices)s. Default: %(default)s”,
“name”: “feature-type”,
“value”: “sift”,
“type”: “enum”
“domain”: [
“high”,
“medium”,
“low”,
“lowest”
“help”: “Set feature extraction quality. Higher quality generates better features, but requires more memory and takes longer. Can be one of: %(choices)s. Default: %(default)s”,
“name”: “feature-quality”,
“value”: “high”,
“type”: “enum”
“domain”: [
“flann”,
“bow”
“help”: “Matcher algorithm, Fast Library for Approximate Nearest Neighbors or Bag of Words. FLANN is slower, but more stable. BOW is faster, but can sometimes miss valid matches. Can be one of: %(choices)s. Default: %(default)s”,
“name”: “matcher-type”,
“value”: “flann”,
“type”: “enum”
“help”: “Number of nearest images to pre-match based on GPS exif data. Set to 0 to skip pre-matching. Neighbors works together with Distance parameter, set both to 0 to not use pre-matching. Default: %(default)s”,
“name”: “matcher-neighbors”,
“value”: “8”,
“type”: “int”
“help”: “Distance threshold in meters to find pre-matching images based on GPS exif data. Set both matcher-neighbors and this to 0 to skip pre-matching. Default: %(default)s”,
“name”: “matcher-distance”,
“value”: “0”,
“type”: “int”
“domain”: “”,
“help”: “Turn off camera parameter optimization during bundle adjustment. This can be sometimes useful for improving results that exhibit doming/bowling or when images are taken with a rolling shutter camera. Default: %(default)s”,
“name”: “use-fixed-camera-params”,
“value”: “false”,
“type”: “bool”
“domain”: “json”,
“help”: “Use the camera parameters computed from another dataset instead of calculating them. Can be specified either as path to a cameras.json file or as a JSON string representing the contents of a cameras.json file. Default: %(default)s”,
“name”: “cameras”,
“value”: “”,
“type”: “string”
“domain”: [
“auto”,
“perspective”,
“brown”,
“fisheye”,
“spherical”
“help”: “Set a camera projection type. Manually setting a value can help improve geometric undistortion. By default the application tries to determine a lens type from the images metadata. Can be one of: %(choices)s. Default: %(default)s”,
“name”: “camera-lens”,
“value”: “auto”,
“type”: “enum”
“domain”: [
“none”,
“camera”,
“camera+sun”
“help”: “Set the radiometric calibration to perform on images. When processing multispectral and thermal images you should set this option to obtain reflectance/temperature values (otherwise you will get digital number values). [camera] applies black level, vignetting, row gradient gain/exposure compensation (if appropriate EXIF tags are found) and computes absolute temperature values. [camera+sun] is experimental, applies all the corrections of [camera], plus compensates for spectral radiance registered via a downwelling light sensor (DLS) taking in consideration the angle of the sun. Can be one of: %(choices)s. Default: %(default)s”,
“name”: “radiometric-calibration”,
“value”: “none”,
“type”: “enum”
“domain”: “float <= 1000”,
“help”: “Legacy option (use --pc-quality instead). Controls the density of the point cloud by setting the resolution of the depthmap images. Higher values take longer to compute but produce denser point clouds. Default: %(default)s”,
“name”: “depthmap-resolution”,
“value”: “640”,
“type”: “float”
“domain”: “”,
“help”: “Use a full 3D mesh to compute the orthophoto instead of a 2.5D mesh. This option is a bit faster and provides similar results in planar areas. Default: %(default)s”,
“name”: “use-3dmesh”,
“value”: “false”,
“type”: “bool”
“domain”: “”,
“help”: “Skip generation of a full 3D model. This can save time if you only need 2D results such as orthophotos and DEMs. Default: %(default)s”,
“name”: “skip-3dmodel”,
“value”: “false”,
“type”: “bool”
“domain”: “”,
“help”: “Skip generation of PDF report. This can save time if you don’t need a report. Default: %(default)s”,
“name”: “skip-report”,
“value”: “false”,
“type”: “bool”
“domain”: “integer: 1 <= x <= 300000”,
“help”: “The maximum vertex count of the output mesh. Default: %(default)s”,
“name”: “mesh-size”,
“value”: “200000”,
“type”: “int”
“domain”: “integer: 1 <= x <= 11”,
“help”: “Octree depth used in the mesh reconstruction, increase to get more vertices, recommended values are 8-12. Default: %(default)s”,
“name”: “mesh-octree-depth”,
“value”: “11”,
“type”: “int”
“domain”: “”,
“help”: “Skips dense reconstruction and 3D model generation. It generates an orthophoto directly from the sparse reconstruction. If you just need an orthophoto and do not need a full 3D model, turn on this option. Default: %(default)s”,
“name”: “fast-orthophoto”,
“value”: “false”,
“type”: “bool”
“domain”: “positive float”,
“help”: “Automatically crop image outputs by creating a smooth buffer around the dataset boundaries, shrinked by N meters. Use 0 to disable cropping. Default: %(default)s”,
“name”: “crop”,
“value”: “3”,
“type”: “float”
“domain”: [
“high”,
“medium”,
“low”,
“lowest”
“help”: “Set point cloud quality. Higher quality generates better, denser point clouds, but requires more memory and takes longer. Each step up in quality increases processing time roughly by a factor of 4x.Can be one of: %(choices)s. Default: %(default)s”,
“name”: “pc-quality”,
“value”: “medium”,
“type”: “enum”
“domain”: “”,
“help”: “Classify the point cloud outputs using a Simple Morphological Filter. You can control the behavior of this option by tweaking the --dem-* parameters. Default: %(default)s”,
“name”: “pc-classify”,
“value”: “false”,
“type”: “bool”
“domain”: “”,
“help”: “Export the georeferenced point cloud in CSV format. Default: %(default)s”,
“name”: “pc-csv”,
“value”: “false”,
“type”: “bool”
“domain”: “”,
“help”: “Export the georeferenced point cloud in LAS format. Default: %(default)s”,
“name”: “pc-las”,
“value”: “false”,
“type”: “bool”
“domain”: “”,
“help”: “Export the georeferenced point cloud in Entwine Point Tile (EPT) format. Default: %(default)s”,
“name”: “pc-ept”,
“value”: “false”,
“type”: “bool”
“help”: “Filters the point cloud by removing points that deviate more than N standard deviations from the local mean. Set to 0 to disable filtering. Default: %(default)s”,
“name”: “pc-filter”,
“value”: “2.5”,
“type”: “float”
“domain”: “float >= 0.01”,
“help”: “Filters the point cloud by keeping only a single point around a radius N (in meters). This can be useful to limit the output resolution of the point cloud and remove duplicate points. Set to 0 to disable sampling. Default: %(default)s”,
“name”: “pc-sample”,
“value”: “0.01”,
“type”: “float”
“domain”: “”,
“help”: “Reduce the memory usage needed for depthmap fusion by splitting large scenes into tiles. Turn this on if your machine doesn’t have much RAM and/or you’ve set --pc-quality to high or ultra. Experimental. Default: %(default)s”,
“name”: “pc-tile”,
“value”: “false”,
“type”: “bool”
“domain”: “”,
“help”: “Improve the accuracy of the point cloud by computing geometrically consistent depthmaps. This increases processing time, but can improve results in urban scenes. Default: %(default)s”,
“name”: “pc-geometric”,
“value”: “false”,
“type”: “bool”
“help”: “Simple Morphological Filter elevation scalar parameter. Default: %(default)s”,
“name”: “smrf-scalar”,
“value”: “1.25”,
“type”: “float”
“help”: “Simple Morphological Filter slope parameter (rise over run). Default: %(default)s”,
“name”: “smrf-slope”,
“value”: “0.15”,
“type”: “float”
“help”: “Simple Morphological Filter elevation threshold parameter (meters). Default: %(default)s”,
“name”: “smrf-threshold”,
“value”: “0.5”,
“type”: “float”
“help”: “Simple Morphological Filter window radius parameter (meters). Default: %(default)s”,
“name”: “smrf-window”,
“value”: “18”,
“type”: “float”
“domain”: [
“gmi”,
“area”
“help”: “When texturing the 3D mesh, for each triangle, choose to prioritize images with sharp features (gmi) or those that cover the largest area (area). Default: %(default)s”,
“name”: “texturing-data-term”,
“value”: “gmi”,
“type”: “enum”
“domain”: [
“none”,
“gauss_clamping”,
“gauss_damping”
“help”: “Type of photometric outlier removal method. Can be one of: %(choices)s. Default: %(default)s”,
“name”: “texturing-outlier-removal-type”,
“value”: “gauss_clamping”,
“type”: “enum”
“domain”: “”,
“help”: “Skip normalization of colors across all images. Useful when processing radiometric data. Default: %(default)s”,
“name”: “texturing-skip-global-seam-leveling”,
“value”: “false”,
“type”: “bool”
“domain”: “”,
“help”: “Skip the blending of colors near seams. Default: %(default)s”,
“name”: “texturing-skip-local-seam-leveling”,
“value”: “false”,
“type”: “bool”
“domain”: “”,
“help”: “Keep faces in the mesh that are not seen in any camera. Default: %(default)s”,
“name”: “texturing-keep-unseen-faces”,
“value”: “false”,
“type”: “bool”
“domain”: [
“none”,
“gamma”
“help”: "Turn on gamma tone mapping or none for no tone mapping. Can be one of %(choices)s. Default: %(default)s ",
“name”: “texturing-tone-mapping”,
“value”: “none”,
“type”: “enum”
“domain”: “”,
“help”: “Use this tag if you have a GCP File but want to use the EXIF information for georeferencing instead. Default: %(default)s”,
“name”: “use-exif”,
“value”: “false”,
“type”: “bool”
“domain”: “”,
“help”: “Use this tag to build a DTM (Digital Terrain Model, ground only) using a simple morphological filter. Check the --dem* and --smrf* parameters for finer tuning. Default: %(default)s”,
“name”: “dtm”,
“value”: “false”,
“type”: “bool”
“domain”: “”,
“help”: “Use this tag to build a DSM (Digital Surface Model, ground + objects) using a progressive morphological filter. Check the --dem* parameters for finer tuning. Default: %(default)s”,
“name”: “dsm”,
“value”: “true”,
“type”: “bool”
“domain”: “integer: 1 <= x <= 4”,
“help”: “Number of steps used to fill areas with gaps. Set to 0 to disable gap filling. Starting with a radius equal to the output resolution, N different DEMs are generated with progressively bigger radius using the inverse distance weighted (IDW) algorithm and merged together. Remaining gaps are then merged using nearest neighbor interpolation. Default: %(default)s”,
“name”: “dem-gapfill-steps”,
“value”: “3”,
“type”: “int”
“domain”: “float >= 1”,
“help”: “DSM/DTM resolution in cm / pixel. Note that this value is capped by a ground sampling distance (GSD) estimate. To remove the cap, check --ignore-gsd also. Default: %(default)s”,
“name”: “dem-resolution”,
“value”: “2”,
“type”: “float”
“domain”: “positive integer”,
“help”: “Decimate the points before generating the DEM. 1 is no decimation (full quality). 100 decimates ~99%% of the points. Useful for speeding up generation of DEM results in very large datasets. Default: %(default)s”,
“name”: “dem-decimation”,
“value”: “1”,
“type”: “int”
“domain”: “”,
“help”: “Computes an euclidean raster map for each DEM. The map reports the distance from each cell to the nearest NODATA value (before any hole filling takes place). This can be useful to isolate the areas that have been filled. Default: %(default)s”,
“name”: “dem-euclidean-map”,
“value”: “false”,
“type”: “bool”
“help”: “Orthophoto resolution in cm / pixel. Note that this value is capped by a ground sampling distance (GSD) estimate. To remove the cap, check --ignore-gsd also. Default: %(default)s”,
“name”: “orthophoto-resolution”,
“value”: “2”,
“type”: “float”
“domain”: “”,
“help”: “Set this parameter if you want a striped GeoTIFF. Default: %(default)s”,
“name”: “orthophoto-no-tiled”,
“value”: “false”,
“type”: “bool”
“domain”: “”,
“help”: “Set this parameter if you want to generate a PNG rendering of the orthophoto. Default: %(default)s”,
“name”: “orthophoto-png”,
“value”: “false”,
“type”: “bool”
“domain”: “”,
“help”: “Set this parameter if you want to generate a Google Earth (KMZ) rendering of the orthophoto. Default: %(default)s”,
“name”: “orthophoto-kmz”,
“value”: “false”,
“type”: “bool”
“domain”: [
“JPEG”,
“LZW”,
“PACKBITS”,
“DEFLATE”,
“LZMA”,
“NONE”
“help”: “Set the compression to use for orthophotos. Can be one of: %(choices)s. Default: %(default)s”,
“name”: “orthophoto-compression”,
“value”: “DEFLATE”,
“type”: “enum”
“domain”: “”,
“help”: “Generates a polygon around the cropping area that cuts the orthophoto around the edges of features. This polygon can be useful for stitching seamless mosaics with multiple overlapping orthophotos. Default: %(default)s”,
“name”: “orthophoto-cutline”,
“value”: “false”,
“type”: “bool”
“domain”: “”,
“help”: “Generate static tiles for orthophotos and DEMs that are suitable for viewers like Leaflet or OpenLayers. Default: %(default)s”,
“name”: “tiles”,
“value”: “false”,
“type”: “bool”
“domain”: “”,
“help”: “Build orthophoto overviews for faster display in programs such as QGIS. Default: %(default)s”,
“name”: “build-overviews”,
“value”: “false”,
“type”: “bool”
“domain”: “”,
“help”: “Create Cloud-Optimized GeoTIFFs instead of normal GeoTIFFs. Default: %(default)s”,
“name”: “cog”,
“value”: “false”,
“type”: “bool”
“domain”: “”,
“help”: “Print additional messages to the console. Default: %(default)s”,
“name”: “verbose”,
“value”: “false”,
“type”: “bool”
“domain”: “”,
“help”: “Print debug messages. Default: %(default)s”,
“name”: “debug”,
“value”: “false”,
“type”: “bool”
“domain”: [
“all”,
“pointcloud”,
“orthophoto”,
“dem”
“help”: “Choose what to merge in the merge step in a split dataset. By default all available outputs are merged. Options: %(choices)s. Default: %(default)s”,
“name”: “merge”,
“value”: “all”,
“type”: “enum”
“domain”: “”,
“help”: “Use images’ GPS exif data for reconstruction, even if there are GCPs present.This flag is useful if you have high precision GPS measurements. If there are no GCPs, this flag does nothing. Default: %(default)s”,
“name”: “force-gps”,
“value”: “false”,
“type”: “bool”
“help”: “Set a value in meters for the GPS Dilution of Precision (DOP) information for all images. If your images are tagged with high precision GPS information (RTK), this value will be automatically set accordingly. You can use this option to manually set it in case the reconstruction fails. Lowering this option can sometimes help control bowling-effects over large areas. Default: %(default)s”,
“name”: “gps-accuracy”,
“value”: “10”,
“type”: “float”
“domain”: “”,
“help”: “Delete heavy intermediate files to optimize disk space usage. This affects the ability to restart the pipeline from an intermediate stage, but allows datasets to be processed on machines that don’t have sufficient disk space available. Default: %(default)s”,
“name”: “optimize-disk-space”,
“value”: “true”,
“type”: “bool”
“domain”: “string”,
“help”: “When processing multispectral datasets, you can specify the name of the primary band that will be used for reconstruction. It’s recommended to choose a band which has sharp details and is in focus. Default: %(default)s”,
“name”: “primary-band”,
“value”: “auto”,
“type”: “string”
“domain”: “”,
“help”: “When processing multispectral datasets, ODM will automatically align the images for each band. If the images have been postprocessed and are already aligned, use this option. Default: %(default)s”,
“name”: “skip-band-alignment”,
“value”: “false”,
“type”: “bool”
Usually the hang during upload is an issue with internet connectivity/stability.
Could you please provide the results of something like speed.cloudflare.com?
We may also have to check for packet loss if the above looks decent.
yep of course…
Yeah, that’s a bit on the lower side of bandwidth.
Could you please run this packet loss test (Default profile)?:
https://packetlosstest.com/
Should look something like this:
Of course…
i suspect that that the lumpiness of the 4g broadband is worse than these results.
The non Lightning version using 16G RAM processed in 2hrs, so overnight processing or dedicated PC may be the answer in the long-term.
Yeah, that might be the best bet if your Internet Service Quality is out of your control and causing you issues.
I apologize for the trouble you’ve had, but hopefully you have a viable path forward from here.
Please let us know as things develop for you!
Many thanks. I got onto a slightly faster broadband network today and the results flew through. So it’s good to know that just a little bit of a faster (or more stable) connection does the trick.
Glad to hear you had success!
Yeah, service quality is very important for reliability with Lightning processing right now. Piero has been doing a lot of work trying to make it more robust to variable service quality recently, but we clearly have more to tighten up!
