Ground Control Point do not appear on the map
can someone please help me with GCP?
When I upload a document (.txt) with these points :
+proj=longlat +ellps=WGS84 +datum=WGS84 +no_defs
GCP01; 15.358089035615; 49.427604065139; 677.006
GCP02; 15.362926670842; 49.428876002527; 655.005
GCP03; 15.362967557993; 49.431148117509; 657.999
GCP04; 15.35968352327; 49.433711781626; 674.996
GCP05; 15.365370406784; 49.434079396988; 654.997
GCP06; 15.366031698483; 49.430233548022; 663.003
GCP07; 15.370923751422; 49.428091514718; 686.01
GCP08; 15.368731046566; 49.423365581498; 691.021
GCP09; 15.365588325429; 49.427495301099; 671.009
GCP10; 15.360669040494; 49.424609877441; 682.014
these points do not show on the map.
I tried to edit the document several times (change the semicolon to a comma), convert the coordinates to other coordinates, but I still don’t see the points on the map and then I can’t add location to photos.
Thanks for help.
You needed to replace the semi colon with a comma AND remove the spaces between columns. This text works in the GCP Editor.
GCP01,15.358089035615,49.427604065139,677.006
GCP02,15.362926670842,49.428876002527,655.005
GCP03,15.362967557993,49.431148117509,657.999
GCP04,15.35968352327,49.433711781626,674.996
GCP05,15.365370406784,49.434079396988,654.997
GCP06,15.366031698483,49.430233548022,663.003
GCP07,15.370923751422,49.428091514718,686.01
GCP08,15.368731046566,49.423365581498,691.021
GCP09,15.365588325429,49.427495301099,671.009
GCP10,15.360669040494,49.424609877441,682.014
Thank you so much, it already works. I do something similar, but probably wrong.
Have a nice day.
