I have 2 nodes that have different issues with the same data but both are not running with the GPU
I have WebODM installed on a computer which has a Ryzen 5900X and a Radeon 6900XT. When running the dataset on this node/machine it gives me this:
[INFO] Running opensfm stage
[INFO] Maximum photo dimensions: 4000px
[INFO] Photo dimensions for feature extraction: 4000px
[INFO] No CUDA drivers detected, using CPU
The main docs advise GPU support is Open-CL based so not how to tell ODM to look for other processors besides cuda.
On the second node, (same WebODM from first machine but the second node is running nodeodm:gpu on docker on a second machine) it has a Threadripper 3960X with a GeForce 1080TI. When running the same dataset it gives me this:
[WARNING] Image size (4000x3000px) would not fit in GPU memory, falling back to CPU
After checking the memory of the GPU, it is empty. I think this model has 11GB of memory so I was surprised a single photo wouldnt fit.
Is there anything I can do to improve this? I’m running large datasets and any improvement on time done would be awesome!
