GPU processing failing
Hello, I am running into issues while processing with the mygla test dataset on GPU which works fine on the regular CPU. I am getting following error:
File "/code/opendm/mesh.py", line 207, in screened_poisson_reconstruction
system.run('"{reconstructmesh}" -i "{infile}" '
[ERROR]   Uh oh! Processing stopped because of strange values in the reconstruction. This is often a sign that the input data has some issues or the software cannot deal with it. Have you followed best practices for data acquisition? See https://docs.opendronemap.org/flying/
Using following options:
{'dsm': True, 'fast-orthophoto' : True, 'orthophoto-resolution': 6}
Using following specs:
Operating system:
Linux (ubuntu 20.04)
Publisher:
nvidia
Size:
Standard NC12:
Anyone know if this is a know issue?
Best Regards,
Rasmus
Hmm… I wonder if maybe the GPU is running out of vRAM.
Does your host tell you how much vRAM the GPUs have?
Here is the specs I used the second one, so it seems to be 24 GiB GPU memory
Tried the big boy Standard_NC24 failed as well, the job fails 50% in.
Just to make sure, GPU processing does work right?
Whoop, nope.
See Piero’s post below.
Thanks for the information! Appreciate it!
Best Regards,
Rasmus
It does work now with the newest image!
