My PC:
CPU: i90-9900k
GPU: NVidia 1080
Ram: 72gb
Windows 10 pro
Docker fully installed and running
ODM running in browser just fine
What I have done:
I have read the forum posts regarding this issue. Most deal with Linux as the environment.
(HERE) AND (HERE) Did I miss another more pertinent post? -
I have followed the windows instructions for updating/installing WSL (cant post link, already used my two for new user)
I have the nvidia/CUDA container in docker (will not start - errors out)
(((Error invoking remote method 'docker-start-container': Error: (HTTP code 500) server error - failed to create shim task: OCI runtime create failed: runc create failed: unable to start container process: error during container init: error running hook #0: error running hook: exit status 1, stdout: , stderr: Auto-detected mode as 'legacy' nvidia-container-cli: initialization error: WSL environment detected but no adapters were found: unknown)))
container id (laughing_engelbart): e25d1526eecc5b133f997e5bf97292df4aee155aa20befeb694871696d0fb1b0
- I have updated my GPU drivers, Updates WLS, and downloaded the most recent Nvicia/cuda lib for WLS (Version 11.7). I have no windows updates needed according to windows.
**| NVIDIA-SMI 516.59 Driver Version: 516.59 CUDA Version: 11.7 |**
**| GPU Name TCC/WDDM | Bus-Id Disp.A | Volatile Uncorr. ECC |**
**| Fan Temp Perf Pwr:Usage/Cap| Memory-Usage | GPU-Util Compute M. |**
**| | | MIG M. |**
**| 0 NVIDIA GeForce ... WDDM | 00000000:01:00.0 On | N/A |**
**| 22% 54C P0 48W / 198W | 682MiB / 8192MiB | 0% Default |**
**| | | N/A |**
**| Processes: |**
**| GPU GI CI PID Type Process name GPU Memory |**
**| ID ID Usage |**
**| 0 N/A N/A 704 C+G ...lPanel\SystemSettings.exe N/A |**
**| 0 N/A N/A 3764 C+G ...ekyb3d8bbwe\HxOutlook.exe N/A |**
**| 0 N/A N/A 10340 C+G C:\Windows\explorer.exe N/A |**
**| 0 N/A N/A 11256 C+G ...artMenuExperienceHost.exe N/A |**
**| 0 N/A N/A 11740 C+G ...5n1h2txyewy\SearchApp.exe N/A |**
**| 0 N/A N/A 12348 C+G ...5n1h2txyewy\SearchApp.exe N/A |**
**| 0 N/A N/A 13740 C+G ...y\ShellExperienceHost.exe N/A |**
**| 0 N/A N/A 16420 C+G ...Docker\Docker Desktop.exe N/A |**
**| 0 N/A N/A 19472 C+G ...2txyewy\TextInputHost.exe N/A |**
**| 0 N/A N/A 21376 C+G ...ontend\Docker Desktop.exe N/A |**
When I open the webODM I use the command ./webodm.sh --gpu start
. Nothing.
I saw on another post that I may need to add a line to the docker-compose.nodeodm.gpu.nvidia.yml
that provides privilege’s. But I didn’t see how that line was added.
