I was monitoring GPU usage continuously. For the feature extraction, GPU was being used. Now, matching process is going on and there is no usage of GPU as such. Feature matching and building sparse point cloud is quite a lengthy process.
This led me to wondering whether all the steps involved use GPU or not.
Which are the steps where GPU is being used?
Has anyone compared the time taken between CPU based processed and GPU based processing?
NVIDIA Tesla T4 has a memory of 16 GB. But after observing for quite a sometime, I see GPU memory usage is 0.5 GB. Even for feature extraction, the GPU memory was not consumed more than 0.5 GB.
I have started webodm using the following command: sudo ./webodm.sh --gpu start
Is it the normal way WebODM works with GPU?
If not, how can utilize the maximum memory of the GPU?
For now, I tested with GoPro Hero 10 dataset now. It has 23 MP and the image size varies from 10 MB to 14MB more or less.
But the last dataset which I processed was of M2P and the image size varied from again 11 to 13 MB.
And when both the dataset were being processed, the GPU memory did not exceed beyond 0.5 GB to 0.6 GB. In both the projects, there were roughly 1000 images.
Assuming you were using ultra quality feature extraction and no resizing, thatās a bit strange. Thatās similar to the VRAM use I see with M2P resized to 3644 wide, and then using medium quality feature extraction.
I think high feature quality overrides the 2048 default if you donāt change it.
If you want to use more of your GPU capability you could use ultra quality feature extraction and set resize to -1, and donāt use the initial resize option, use āNoā.
In my testing, processing 20MPx images with no resizing and feature-quality=Ultra used a maximum of 7.4GB of VRAM.
With feature-quality=High and resizing the 20MPx images to 2048x1355px that reduced that to a maximum of 0.6GB VRAM.
Right now, looking at the logs, 2022-09-04 03:54:04,076 INFO: ht_0243_102.JPG resection inliers: 1412 / 1661 2022-09-04 03:54:04,099 INFO: Adding ht_0243_102.JPG to the reconstruction
I am trying to understand which process does this line suggest? Is it the sparse point cloud generation step?
Using htop command, I can see the output as python3/code/SuperBuild/install/bin/opensfm/bin/opensfm_main.py rs_correct /var/www/data/06e05a1c-9014-4be9-a0f0-d0b7223162aa/opensfm
I was searching and found my own Ticket:
Seems like this process does not use GPU and moreover does not utilize all the cores. Hence, it kinds of defeat the purpose of using GPU as GPU remains idle. This remains right now the longest time taking process.
I think you better play with parameters to gain time.
I upgraded from 2.7.1 where I got an error message about the GPU (maybe from bigger image size than GPU can handle) now with 2.8.8 I canāt see any error after āCUDA detectedā, but I can only spot a few very short spikes in GPU activity, like 4-5 x 1 second over >1 hour processing.
I suppose this is similar to this AI stuff, you have all these free tools to build a project, but when it comes to process something serious, you need to use their own servicesā¦
