BTW here are my settings and the processing starting point:
[INFO] Initializing ODM 2.8.4 - Mon May 23 14:39:17 2022
[INFO] ==============
[INFO] auto_boundary: True
[INFO] boundary: {}
[INFO] build_overviews: False
[INFO] camera_lens: auto
[INFO] cameras: {}
[INFO] cog: True
[INFO] copy_to: None
[INFO] crop: 3
[INFO] debug: False
[INFO] dem_decimation: 1
[INFO] dem_gapfill_steps: 3
[INFO] dem_resolution: 5
[INFO] dsm: True
[INFO] dtm: False
[INFO] fast_orthophoto: False
[INFO] feature_quality: high
[INFO] feature_type: sift
[INFO] force_gps: True
[INFO] gcp: None
[INFO] geo: None
[INFO] gps_accuracy: 0.2
[INFO] ignore_gsd: True
[INFO] matcher_neighbors: 200
[INFO] matcher_type: flann
[INFO] max_concurrency: 4
[INFO] merge: all
[INFO] mesh_octree_depth: 11
[INFO] mesh_size: 200000
[INFO] min_num_features: 80000
[INFO] name: 37ef1a14-5e65-4d1e-943e-e54ddd184998
[INFO] orthophoto_kmz: False
[INFO] orthophoto_png: False
[INFO] pc_classify: False
[INFO] pc_copc: False
[INFO] pc_csv: False
[INFO] pc_ept: True
[INFO] pc_filter: 2.5
[INFO] pc_geometric: False
[INFO] pc_las: False
[INFO] pc_quality: medium
[INFO] pc_rectify: False
[INFO] pc_sample: 0
[INFO] pc_tile: False
[INFO] primary_band: auto
[INFO] project_path: D:\WebODM\resources\app\apps\NodeODM\data
[INFO] rerun: None
[INFO] rerun_all: False
[INFO] rerun_from: [‘dataset’, ‘split’, ‘merge’, ‘opensfm’, ‘openmvs’, ‘odm_filterpoints’, ‘odm_meshing’, ‘mvs_texturing’, ‘odm_georeferencing’, ‘odm_dem’, ‘odm_orthophoto’, ‘odm_report’, ‘odm_postprocess’]
[INFO] resize_to: 2048
[INFO] skip_3dmodel: False
[INFO] skip_orthophoto: False
[INFO] skip_report: False
[INFO] sm_cluster: None
[INFO] smrf_scalar: 1.25
[INFO] smrf_slope: 0.15
[INFO] smrf_threshold: 0.5
[INFO] smrf_window: 18.0
[INFO] split: 999999
[INFO] split_overlap: 150
[INFO] tiles: False
[INFO] time: False
[INFO] use_3dmesh: False
[INFO] use_exif: True
[INFO] verbose: False
[INFO] Running dataset stage
[INFO] Loading dataset from: D:\WebODM\resources\app\apps\NodeODM\data\37ef1a14-5e65-4d1e-943e-e54ddd184998\images
[INFO] Loading 1069 images
[INFO] Wrote images database: D:\WebODM\resources\app\apps\NodeODM\data\37ef1a14-5e65-4d1e-943e-e54ddd184998\images.json
[INFO] Found 1069 usable images
And here is where Webodm is at for the past 3 days now
2022-05-26 09:35:09,243 DEBUG: Matching FP_07_DSC00782.JPG and FP_07_DSC00737.JPG. Matcher: WORDS (symmetric) T-desc: 6.138 T-robust: 2.134 T-total: 8.273 Matches: 32 Robust: 10 Success: False
2022-05-26 09:35:14,059 DEBUG: Matching FP_07_DSC00342.JPG and FP_07_DSC00942.JPG. Matcher: WORDS (symmetric) T-desc: 22.174 T-robust: 1.314 T-total: 23.489 Matches: 41 Robust: 9 Success: False
2022-05-26 09:35:15,334 DEBUG: Matching FP_07_DSC00561.JPG and FP_07_DSC00800.JPG. Matcher: WORDS (symmetric) T-desc: 20.612 T-robust: 0.020 T-total: 20.632 Matches: 33 Robust: 9 Success: False
2022-05-26 09:35:15,419 DEBUG: No segmentation for FP_07_DSC00313.JPG, no features masked.
2022-05-26 09:35:19,408 DEBUG: Matching FP_07_DSC00361.JPG and FP_07_DSC00844.JPG. Matcher: WORDS (symmetric) T-desc: 10.148 T-robust: 0.018 T-total: 10.166 Matches: 34 Robust: 9 Success: False
2022-05-26 09:35:22,998 DEBUG: Matching FP_07_DSC00026.JPG and FP_07_DSC00150.JPG. Matcher: WORDS (symmetric) T-desc: 7.642 T-robust: 0.019 T-total: 7.663 Matches: 37 Robust: 9 Success: False
2022-05-26 09:35:25,970 DEBUG: Matching FP_07_DSC00559.JPG and FP_07_DSC00059.JPG. Matcher: WORDS (symmetric) T-desc: 10.635 T-robust: 0.021 T-total: 10.656 Matches: 44 Robust: 10 Success: False
2022-05-26 09:35:30,473 DEBUG: Matching FP_07_DSC00313.JPG and FP_07_DSC00604.JPG. Matcher: WORDS (symmetric) T-desc: 21.213 T-robust: 0.017 T-total: 21.230 Matches: 30 Robust: 9 Success: False
2022-05-26 09:35:34,060 DEBUG: Matching FP_07_DSC00086.JPG and FP_07_DSC00670.JPG. Matcher: WORDS (symmetric) T-desc: 14.627 T-robust: 0.025 T-total: 14.652 Matches: 38 Robust: 9 Success: False
2022-05-26 09:35:37,335 DEBUG: Matching FP_07_DSC00806.JPG and FP_07_DSC00223.JPG. Matcher: WORDS (symmetric) T-desc: 14.307 T-robust: 0.028 T-total: 14.335 Matches: 37 Robust: 10 Success: False
Any feed back on the settings is most welcome.
Thanks in advance
