I am looking for a way to “merge” the data from the meshed point cloud and the georeferenced one.
I need a colored georeferenced and meshed pointcloud.
Am-I missing an output or a parameter in ODM or is there a way to achieve this with the outputs ?
Thank you for your reply, I will have a look at what can be done with CloudCompare. I am already using it for other purposes but I was hopping for a command line tool in order to automatise the process, perhaps something with pdal ?
Editing the odm_georeferencing.py file with '--writers.las.extra_dims="all"' I managed to retrieve the normals in the georeferenced odm_georeferenced_model.laz file.
But currently I am stuck there. I do not manage to recreate a mesh from this .laz file and conversion to .ply does not give better results…
Not sure either to what transformation to apply to the mesh. I think I have tried it but says it has no srs so no transformation is possible.
