So I have some GCP items I want to add to the interface. When I put the txt file with the GCP locations in nothing shows up on the map side of things. Here is my file for my GCP
Blockquote
Create a GCP list that only includes gcp name (this is the label that will be seen in the GCP interface), x, y, and z, with a header with a proj4 string of your GCPs (make sure they are in a planar coordinate system, such as UTM.
Blockquote . I think you need to change the settings on your GPS unit or convert the lat+longs to a planar coordinate system- like WGS84 UTM 16N. I didn’t realize GCPi only take planar coordinates. Sorry for the confusion.
