WebODM does not seem to recognize a local reference system for GCPs.
This is the proj string I use:
+proj=merc +lat_0=45.9318804994 +lon_0=12.7230707318 +k=1 +x_0=0 +y_0=0 +ellps=WGS84 +towgs84=0,0,0,0,0,0,0 +units=m +no_defs
This is the output log:
[INFO] Running dataset stage
[INFO] Loading dataset from: /var/www/data/da6806d5-ba1d-4173-a5f3-86038b9b9e19/images
[INFO] Loading 148 images
[INFO] Wrote images database: /var/www/data/da6806d5-ba1d-4173-a5f3-86038b9b9e19/images.json
[INFO] Found 148 usable images
[INFO] Parsing SRS header: +proj=merc +lat_0=45.9318804994 +lon_0=12.7230707318 +k=1 +x_0=0 +y_0=0 +ellps=WGS84 +towgs84=0,0,0,0,0,0,0 +units=m +no_defs
[INFO] Generated coords file from GCP: WGS84 UTM 33N
[INFO] Parsing SRS header: WGS84 UTM 33N
[INFO] 39 GCP points will be used for georeferencing
[INFO] Finished dataset stage
[INFO] Running split stage
[INFO] Finished split stage
[INFO] Running merge stage
[INFO] Finished merge stage
[INFO] Running opensfm stage
[INFO] Writing exif overrides
[INFO] Maximum photo dimensions: 4000px
It seems to always use WGS84 UTM 33N.
At the end the processing stops with this message:
[INFO] running gdal_translate -co NUM_THREADS=12 --config GDAL_CACHEMAX 44.45% -outsize 10% 0 /var/www/data/da6806d5-ba1d-4173-a5f3-86038b9b9e19/odm_meshing/tmp/tiles.tmp.tif /var/www/data/da6806d5-ba1d-4173-a5f3-86038b9b9e19/odm_meshing/tmp/tiles.small.tif
ERROR 5: Invalid output width: 0.7
Input file size is 7, 8
File “/code/run.py”, line 68, in
app.execute()
File “/code/stages/odm_app.py”, line 95, in execute
File “/code/opendm/types.py”, line 356, in run
[Previous line repeated 2 more times]
File “/code/opendm/types.py”, line 337, in run
File “/code/stages/odm_meshing.py”, line 75, in process
smooth_dsm=not args.fast_orthophoto)
File “/code/opendm/mesh.py”, line 35, in create_25dmesh
apply_smoothing=smooth_dsm
File “/code/opendm/dem/commands.py”, line 225, in create_dem
‘{geotiff_tmp} {geotiff_small}’.format(**kwargs))
Exception: Child returned 1
/usr/local/lib/python3.6/dist-packages/sklearn/externals/joblib/externals/cloudpickle/cloudpickle.py:47: DeprecationWarning: the imp module is deprecated in favour of importlib; see the module’s documentation for alternative uses
import imp
Thanks for the suppot
