GCP Medium sea Level / point elevation
Hello, i hope you good there guys.
im new using WEBODM to process images. im trying to work in real medium sea level points elevation. i process the pictures with 3GCP but the 3D model just have the correct elevation in one GCP.
how can i fix it ?
thanks in advance
How many images are you tagging per GCP?
How well-distributed are your GCPs across your study site?
Hello Naib,
10 images + o - per GCP
about the distribution
How are you collecting the GCP?
Are you using a marker, hand-held GPS? RTK?
RTK and total station Combination.
N,E,Z
2052929.065,388843.399,81.128
2052751.631,388751.138,77.692
2052783.906,388805.936,91.073
And what are you using as GCP markers in your scene? Can you reliably pick the same spot?
pant & yes,
i make a 3D model with other pictures in other zone and its good result.
idk here what happen
Which GCP is working properly?
Anything different about the other two?
the middle is working good!
the other have 10 meters diferent MSL + o -
if you want i can send you the images
Sure, if you like you can upload the images and the gcp_list.txt to dronedb.app and I’ll try to take a look at it soon to see if anything obvious is amiss.
send you the link drive by mail
oiyndunl863zdqcv DroneDB
