GCP Issues
I am new at WEBODM, I am trying to work with GCP Interface. But it has not worked for me.
I created a file, as I saw in some guides, and does not load any points
I tried a second file, with differten format, the GCP are loaded, in the correct easting but the northing is wrong, no matter which cordinate is in the northing it always locate it on the “north pole”.
And eveb though I had that probelm tried to load some pictures, and it ddn not work.
GCP1
GCP2
Change your commas to decimal points, and it should work better for you.
Thaks a lot, really helpfull.
Gracias.
