GCP editor Pro
Good morning. I have recently purchased a license to GCP Editor Pro. Could someone guide me on where to actually key in my license number to gain access to this feature? TIA
Did you download the program? https://uav4geo.com/software/gcpeditorpro Check the download links at the bottom of the page.
It asks for the key as soon as you launch it.
I did not. Thanks for the info. I will give it a try.
I think you’ll really like it! I’ve found it hugely helpful and intuitive!
Awesome! I can’t wait to try it out.
Alright. I have produced a file from the GCP Editor Pro. Now, how do I bring it into my project and reprocess it with the gcp file?
Check out the documentation here and let us know if you need more help:
https://docs.opendronemap.org/gcp.html#
That is just what I was looking for. Thanks.
Do you process the images without the GCP file first and then reprocess them after adding the GCP file or do you you drag in all of your images plus the created GCP text file and start the process?
All together at the start!
(Unless you are unsure about the dataset and want to process without first to test)
Ok. Good.
