GCP Editor Pro commandline support?
I have today started to use GCP Editor Pro. It looks like an excellent tool. I do generate the import CSV file in another software and would like to start GCP Edit Pro and have it automatically load the CSV file I have made elsewhere. (I will afterward of course do the matching of pictures manually)
I have tried to start GCP Editor with the CSV-filename as a parameter in command line, but it looks like it does not support that. Does anyone know if this is possible and what the syntax is ?
I am running GCP Editor Pro windows standalone version.
Currently it’s not possible (would be an interesting feature to add). Open a feature/pull request? :pray: GitHub - uav4geo/GCPEditorPro: Amazingly fast and simple ground control points interface. β—Ž
Thanks - I will put in a pull request.
