GCP Editor plugin install issue
I’d like to test GCP Editor Pro on WebODM (installed via Docker on an Ubuntu server).
I downloaded the latest Plugin version and uploaded successfully: it is listed in green in the plugin list and a button appears on the left side in WebODM. However I’m getting a 404 error . I attach screenshot showing the folder structure of the .zip for the plugin.
Is the port not :8000 for the plugin? Thank you
Mm, strange. Did you try restarting WebODM?
Restarting solved it.
Thank you
