GCP and Georeferencing
I understand that the minimum number of GCPs needed for georeferencing (if using GCPs) is three and each of those GCPs must reference at least three corresponding image-tiles.
For example:
+proj=utm +zone=19 +ellps=WGS84 +datum=WGS84 +units=m +no_defs
What happens if you reference a fourth or fifth GCP, but in less than three images like so?:
Are those ignored or do they nullify the entire gcp_list.txt file?
