Hello. I just did a fresh install of Ubuntu Server 16.04 LTS and using the WebODM Ubuntu Server Installer that I purchased to install. The Installer seems to run fine and finishes without an issue. When I load the URL in the browser I get the following error. I’d like some guidance as to what needs done to fix this.
ProgrammingError at /
relation “auth_user” does not exist
LINE 1: SELECT COUNT() AS “__count” FROM “auth_user” WHERE "auth_us…
Request Method: GET
Request URL: http://192.168.48.131/
Django Version: 2.1.7
Exception Type: ProgrammingError
Exception Value:
Exception Location: /webodm/python3-venv/lib/python3.5/site-packages/django/db/backends/utils.py in _execute, line 85
Python Executable: /webodm/python3-venv/bin/python3
Python Version: 3.5.2
Python Path:
[’/webodm’,
‘/webodm/python3-venv/bin’,
‘/webodm/python3-venv/lib/python35.zip’,
‘/webodm/python3-venv/lib/python3.5’,
‘/webodm/python3-venv/lib/python3.5/plat-x86_64-linux-gnu’,
‘/webodm/python3-venv/lib/python3.5/lib-dynload’,
‘/usr/lib/python3.5’,
‘/usr/lib/python3.5/plat-x86_64-linux-gnu’,
‘/webodm/python3-venv/lib/python3.5/site-packages’,
‘/webodm’]
Server time: Thu, 14 Mar 2019 15:18:57 -0700
Traceback:
Environment:
Request Method: GET
Installed Applications:
[‘django.contrib.admin’,
‘django.contrib.auth’,
‘django.contrib.contenttypes’,
‘django.contrib.sessions’,
‘django.contrib.messages’,
‘django.contrib.staticfiles’,
‘django.contrib.gis’,
‘django_filters’,
‘guardian’,
‘rest_framework’,
‘rest_framework_nested’,
‘webpack_loader’,
‘corsheaders’,
‘colorfield’,
‘imagekit’,
‘codemirror2’,
‘compressor’,
‘app’,
‘nodeodm’]
Installed Middleware:
[‘corsheaders.middleware.CorsMiddleware’,
‘django.middleware.security.SecurityMiddleware’,
‘django.contrib.sessions.middleware.SessionMiddleware’,
‘django.middleware.common.CommonMiddleware’,
‘django.middleware.csrf.CsrfViewMiddleware’,
‘django.contrib.auth.middleware.AuthenticationMiddleware’,
‘django.contrib.messages.middleware.MessageMiddleware’,
‘django.middleware.locale.LocaleMiddleware’]
Traceback:
File “/webodm/python3-venv/lib/python3.5/site-packages/django/db/backends/utils.py” in _execute
85. return self.cursor.execute(sql, params)
The above exception (relation “auth_user” does not exist
LINE 1: SELECT COUNT(*) AS “__count” FROM “auth_user” WHERE "auth_us…
) was the direct cause of the following exception:
File “/webodm/python3-venv/lib/python3.5/site-packages/django/core/handlers/exception.py” in inner
34. response = get_response(request)
File “/webodm/python3-venv/lib/python3.5/site-packages/django/core/handlers/base.py” in _get_response
126. response = self.process_exception_by_middleware(e, request)
124. response = wrapped_callback(request, *callback_args, **callback_kwargs)
File “/webodm/app/views/app.py” in index
20. if User.objects.filter(is_superuser=True).count() == 0:
File “/webodm/python3-venv/lib/python3.5/site-packages/django/db/models/query.py” in count
383. return self.query.get_count(using=self.db)
File “/webodm/python3-venv/lib/python3.5/site-packages/django/db/models/sql/query.py” in get_count
498. number = obj.get_aggregation(using, [’__count’])[’__count’]
File “/webodm/python3-venv/lib/python3.5/site-packages/django/db/models/sql/query.py” in get_aggregation
483. result = compiler.execute_sql(SINGLE)
File “/webodm/python3-venv/lib/python3.5/site-packages/django/db/models/sql/compiler.py” in execute_sql
1065. cursor.execute(sql, params)
File “/webodm/python3-venv/lib/python3.5/site-packages/django/db/backends/utils.py” in execute
100. return super().execute(sql, params)
68. return self._execute_with_wrappers(sql, params, many=False, executor=self._execute)
File “/webodm/python3-venv/lib/python3.5/site-packages/django/db/backends/utils.py” in _execute_with_wrappers
77. return executor(sql, params, many, context)
File “/webodm/python3-venv/lib/python3.5/site-packages/django/db/utils.py” in exit
89. raise dj_exc_value.with_traceback(traceback) from exc_value
Exception Type: ProgrammingError at /
Exception Value: relation “auth_user” does not exist
Request info:
Request information
USER
AnonymousUser
GET
No GET data
POST
No POST data
FILES
No FILES data
COOKIES
No cookie data
META
Variable Value
HTTP_ACCEPT
‘text/html,application/xhtml+xml,application/xml;q=0.9,image/webp,image/apng,/;q=0.8’
HTTP_ACCEPT_ENCODING
‘gzip, deflate’
HTTP_ACCEPT_LANGUAGE
‘en-US,en;q=0.9’
HTTP_CONNECTION
‘close’
HTTP_HOST
‘192.168.48.131’
HTTP_UPGRADE_INSECURE_REQUESTS
‘1’
HTTP_USER_AGENT
(‘Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like ’
‘Gecko) Chrome/72.0.3626.121 Safari/537.36’)
HTTP_X_FORWARDED_FOR
‘192.168.48.1’
PATH_INFO
QUERY_STRING
RAW_URI
REMOTE_ADDR
"b’’"
REQUEST_METHOD
‘GET’
SCRIPT_NAME
SERVER_NAME
‘192.168.48.131’
SERVER_PORT
‘80’
SERVER_PROTOCOL
‘HTTP/1.0’
SERVER_SOFTWARE
‘gunicorn/19.7.1’
gunicorn.socket
<socket.socket fd=12, family=AddressFamily.AF_UNIX, type=SocketKind.SOCK_STREAM, proto=0, laddr=/webodm/gunicorn.sock>
wsgi.errors
<gunicorn.http.wsgi.WSGIErrorsWrapper object at 0x7f1d460511d0>
wsgi.file_wrapper
wsgi.input
<gunicorn.http.body.Body object at 0x7f1d46051278>
wsgi.multiprocess
False
wsgi.multithread
False
wsgi.run_once
False
wsgi.url_scheme
‘http’
wsgi.version
(1, 0)
Settings
Using settings module webodm.settings
Setting Value
ABSOLUTE_URL_OVERRIDES
ADMINS
ALLOWED_HOSTS
APPEND_SLASH
True
AUTHENTICATION_BACKENDS
(‘django.contrib.auth.backends.ModelBackend’,
‘guardian.backends.ObjectPermissionBackend’)
AUTH_PASSWORD_VALIDATORS
AUTH_USER_MODEL
‘auth.User’
BASE_DIR
‘/webodm’
CACHES
{‘default’: {‘BACKEND’: ‘django.core.cache.backends.locmem.LocMemCache’}}
CACHE_MIDDLEWARE_ALIAS
‘default’
CACHE_MIDDLEWARE_KEY_PREFIX
CACHE_MIDDLEWARE_SECONDS
600
CELERY_ACCEPT_CONTENT
[‘json’]
CELERY_BROKER_URL
‘redis://localhost’
CELERY_INCLUDE
[‘worker.tasks’]
CELERY_RESULT_BACKEND
‘redis://localhost’
CELERY_RESULT_SERIALIZER
‘json’
CELERY_TASK_SERIALIZER
‘json’
CELERY_WORKER_HIJACK_ROOT_LOGGER
False
CELERY_WORKER_REDIRECT_STDOUTS
False
COMPRESS_CACHEABLE_PRECOMPILERS
COMPRESS_CACHE_BACKEND
‘default’
COMPRESS_CACHE_KEY_FUNCTION
COMPRESS_CLEAN_CSS_ARGUMENTS
COMPRESS_CLEAN_CSS_BINARY
‘cleancss’
COMPRESS_CLOSURE_COMPILER_ARGUMENTS
COMPRESS_CLOSURE_COMPILER_BINARY
‘java -jar compiler.jar’
COMPRESS_CSS_COMPRESSOR
‘compressor.css.CssCompressor’
COMPRESS_CSS_FILTERS
[‘compressor.filters.css_default.CssAbsoluteFilter’]
COMPRESS_CSS_HASHING_METHOD
‘mtime’
COMPRESS_DATA_URI_MAX_SIZE
1024
COMPRESS_DEBUG_TOGGLE
None
COMPRESS_ENABLED
False
COMPRESS_JINJA2_GET_ENVIRONMENT
<function CompressorConf.JINJA2_GET_ENVIRONMENT at 0x7f1d463f2d08>
COMPRESS_JS_COMPRESSOR
‘compressor.js.JsCompressor’
COMPRESS_JS_FILTERS
[‘compressor.filters.jsmin.JSMinFilter’]
COMPRESS_MINT_DELAY
30
COMPRESS_MTIME_DELAY
10
COMPRESS_OFFLINE
False
COMPRESS_OFFLINE_CONTEXT
{‘STATIC_URL’: ‘/static/’}
COMPRESS_OFFLINE_MANIFEST
‘manifest.json’
COMPRESS_OFFLINE_TIMEOUT
31536000
COMPRESS_OUTPUT_DIR
‘CACHE’
COMPRESS_PARSER
‘compressor.parser.AutoSelectParser’
COMPRESS_PRECOMPILERS
((‘text/x-scss’, ‘django_libsass.SassCompiler’),)
COMPRESS_REBUILD_TIMEOUT
2592000
COMPRESS_ROOT
‘/webodm/build/static’
COMPRESS_STORAGE
‘compressor.storage.CompressorFileStorage’
COMPRESS_TEMPLATE_FILTER_CONTEXT
COMPRESS_URL
‘/static/’
COMPRESS_URL_PLACEHOLDER
‘/compressor_url_placeholder/’
COMPRESS_VERBOSE
False
COMPRESS_YUGLIFY_BINARY
‘yuglify’
COMPRESS_YUGLIFY_CSS_ARGUMENTS
‘–terminal’
COMPRESS_YUGLIFY_JS_ARGUMENTS
‘–terminal’
COMPRESS_YUI_BINARY
‘java -jar yuicompressor.jar’
COMPRESS_YUI_CSS_ARGUMENTS
COMPRESS_YUI_JS_ARGUMENTS
CORS_ALLOW_CREDENTIALS
True
CORS_ORIGIN_ALLOW_ALL
True
CSRF_COOKIE_AGE
31449600
CSRF_COOKIE_DOMAIN
None
CSRF_COOKIE_HTTPONLY
False
CSRF_COOKIE_NAME
‘csrftoken’
CSRF_COOKIE_PATH
CSRF_COOKIE_SAMESITE
‘Lax’
CSRF_COOKIE_SECURE
False
CSRF_FAILURE_VIEW
‘django.views.csrf.csrf_failure’
CSRF_HEADER_NAME
‘HTTP_X_CSRFTOKEN’
CSRF_TRUSTED_ORIGINS
CSRF_USE_SESSIONS
False
DATABASES
{‘default’: {‘ATOMIC_REQUESTS’: False,
‘AUTOCOMMIT’: True,
‘CONN_MAX_AGE’: 0,
‘ENGINE’: ‘django.contrib.gis.db.backends.postgis’,
‘HOST’: ‘localhost’,
‘NAME’: ‘webodm_dev’,
‘OPTIONS’: {},
‘PASSWORD’: '’,
‘PORT’: ‘5432’,
‘TEST’: {‘CHARSET’: None,
‘COLLATION’: None,
‘MIRROR’: None,
‘NAME’: None},
‘TIME_ZONE’: None,
‘USER’: ‘postgres’}}
DATABASE_ROUTERS
DATA_UPLOAD_MAX_MEMORY_SIZE
2621440
DATA_UPLOAD_MAX_NUMBER_FIELDS
None
DATETIME_FORMAT
‘N j, Y, P’
DATETIME_INPUT_FORMATS
[’%Y-%m-%d %H:%M:%S’,
‘%Y-%m-%d %H:%M:%S.%f’,
‘%Y-%m-%d %H:%M’,
‘%Y-%m-%d’,
‘%m/%d/%Y %H:%M:%S’,
‘%m/%d/%Y %H:%M:%S.%f’,
‘%m/%d/%Y %H:%M’,
‘%m/%d/%Y’,
‘%m/%d/%y %H:%M:%S’,
‘%m/%d/%y %H:%M:%S.%f’,
‘%m/%d/%y %H:%M’,
‘%m/%d/%y’]
DATE_FORMAT
‘N j, Y’
DATE_INPUT_FORMATS
[’%Y-%m-%d’,
‘%m/%d/%Y’,
‘%m/%d/%y’,
‘%b %d %Y’,
‘%b %d, %Y’,
‘%d %b %Y’,
‘%d %b, %Y’,
‘%B %d %Y’,
‘%B %d, %Y’,
‘%d %B %Y’,
‘%d %B, %Y’]
DEBUG
True
DEBUG_PROPAGATE_EXCEPTIONS
False
DECIMAL_SEPARATOR
DEFAULT_CHARSET
‘utf-8’
DEFAULT_CONTENT_TYPE
‘text/html’
DEFAULT_EXCEPTION_REPORTER_FILTER
‘django.views.debug.SafeExceptionReporterFilter’
DEFAULT_FILE_STORAGE
‘django.core.files.storage.FileSystemStorage’
DEFAULT_FROM_EMAIL
‘[email protected]’
DEFAULT_INDEX_TABLESPACE
DEFAULT_TABLESPACE
DISALLOWED_USER_AGENTS
EMAIL_BACKEND
‘django.core.mail.backends.smtp.EmailBackend’
EMAIL_HOST
‘localhost’
EMAIL_HOST_PASSWORD
EMAIL_HOST_USER
EMAIL_PORT
25
EMAIL_SSL_CERTFILE
None
EMAIL_SSL_KEYFILE
EMAIL_SUBJECT_PREFIX
‘[Django] ’
EMAIL_TIMEOUT
None
EMAIL_USE_LOCALTIME
False
EMAIL_USE_SSL
False
EMAIL_USE_TLS
False
FILE_CHARSET
‘utf-8’
FILE_UPLOAD_DIRECTORY_PERMISSIONS
None
FILE_UPLOAD_HANDLERS
[‘django.core.files.uploadhandler.MemoryFileUploadHandler’,
‘app.uploadhandler.TemporaryFileUploadHandler’]
FILE_UPLOAD_MAX_MEMORY_SIZE
4718592
FILE_UPLOAD_PERMISSIONS
None
FILE_UPLOAD_TEMP_DIR
None
FIRST_DAY_OF_WEEK
0
FIXTURE_DIRS
FORCE_SCRIPT_NAME
None
FORMAT_MODULE_PATH
None
FORM_RENDERER
‘django.forms.renderers.DjangoTemplates’
IGNORABLE_404_URLS
IMAGEKIT_CACHEFILE_DIR
‘CACHE/images’
IMAGEKIT_CACHEFILE_NAMER
‘imagekit.cachefiles.namers.hash’
IMAGEKIT_CACHE_BACKEND
‘default’
IMAGEKIT_CACHE_PREFIX
‘imagekit:’
IMAGEKIT_CACHE_TIMEOUT
300
IMAGEKIT_DEFAULT_CACHEFILE_BACKEND
‘imagekit.cachefiles.backends.Simple’
IMAGEKIT_DEFAULT_CACHEFILE_STRATEGY
‘imagekit.cachefiles.strategies.JustInTime’
IMAGEKIT_DEFAULT_FILE_STORAGE
IMAGEKIT_SPEC_CACHEFILE_NAMER
‘imagekit.cachefiles.namers.source_name_as_path’
IMAGEKIT_USE_MEMCACHED_SAFE_CACHE_KEY
INSTALLED_APPS
‘django_filters’,
‘guardian’,
‘rest_framework’,
‘webpack_loader’,
‘corsheaders’,
‘colorfield’,
‘imagekit’,
‘codemirror2’,
‘compressor’,
‘app’,
‘nodeodm’]
INTERNAL_IPS
[‘127.0.0.1’]
JWT_AUTH
{‘JWT_EXPIRATION_DELTA’: datetime.timedelta(0, 21600)}
LANGUAGES
[(‘af’, ‘Afrikaans’),
(‘ar’, ‘Arabic’),
(‘ast’, ‘Asturian’),
(‘az’, ‘Azerbaijani’),
(‘bg’, ‘Bulgarian’),
(‘be’, ‘Belarusian’),
(‘bn’, ‘Bengali’),
(‘br’, ‘Breton’),
(‘bs’, ‘Bosnian’),
(‘ca’, ‘Catalan’),
(‘cs’, ‘Czech’),
(‘cy’, ‘Welsh’),
(‘da’, ‘Danish’),
(‘de’, ‘German’),
(‘dsb’, ‘Lower Sorbian’),
(‘el’, ‘Greek’),
(‘en’, ‘English’),
(‘en-au’, ‘Australian English’),
(‘en-gb’, ‘British English’),
(‘eo’, ‘Esperanto’),
(‘es’, ‘Spanish’),
(‘es-ar’, ‘Argentinian Spanish’),
(‘es-co’, ‘Colombian Spanish’),
(‘es-mx’, ‘Mexican Spanish’),
(‘es-ni’, ‘Nicaraguan Spanish’),
(‘es-ve’, ‘Venezuelan Spanish’),
(‘et’, ‘Estonian’),
(‘eu’, ‘Basque’),
(‘fa’, ‘Persian’),
(‘fi’, ‘Finnish’),
(‘fr’, ‘French’),
(‘fy’, ‘Frisian’),
(‘ga’, ‘Irish’),
(‘gd’, ‘Scottish Gaelic’),
(‘gl’, ‘Galician’),
(‘he’, ‘Hebrew’),
(‘hi’, ‘Hindi’),
(‘hr’, ‘Croatian’),
(‘hsb’, ‘Upper Sorbian’),
(‘hu’, ‘Hungarian’),
(‘ia’, ‘Interlingua’),
(‘id’, ‘Indonesian’),
(‘io’, ‘Ido’),
(‘is’, ‘Icelandic’),
(‘it’, ‘Italian’),
(‘ja’, ‘Japanese’),
(‘ka’, ‘Georgian’),
(‘kab’, ‘Kabyle’),
(‘kk’, ‘Kazakh’),
(‘km’, ‘Khmer’),
(‘kn’, ‘Kannada’),
(‘ko’, ‘Korean’),
(‘lb’, ‘Luxembourgish’),
(‘lt’, ‘Lithuanian’),
(‘lv’, ‘Latvian’),
(‘mk’, ‘Macedonian’),
(‘ml’, ‘Malayalam’),
(‘mn’, ‘Mongolian’),
(‘mr’, ‘Marathi’),
(‘my’, ‘Burmese’),
(‘nb’, ‘Norwegian Bokmål’),
(‘ne’, ‘Nepali’),
(‘nl’, ‘Dutch’),
(‘nn’, ‘Norwegian Nynorsk’),
(‘os’, ‘Ossetic’),
(‘pa’, ‘Punjabi’),
(‘pl’, ‘Polish’),
(‘pt’, ‘Portuguese’),
(‘pt-br’, ‘Brazilian Portuguese’),
(‘ro’, ‘Romanian’),
(‘ru’, ‘Russian’),
(‘sk’, ‘Slovak’),
(‘sl’, ‘Slovenian’),
(‘sq’, ‘Albanian’),
(‘sr’, ‘Serbian’),
(‘sr-latn’, ‘Serbian Latin’),
(‘sv’, ‘Swedish’),
(‘sw’, ‘Swahili’),
(‘ta’, ‘Tamil’),
(‘te’, ‘Telugu’),
(‘th’, ‘Thai’),
(‘tr’, ‘Turkish’),
(‘tt’, ‘Tatar’),
(‘udm’, ‘Udmurt’),
(‘uk’, ‘Ukrainian’),
(‘ur’, ‘Urdu’),
(‘vi’, ‘Vietnamese’),
(‘zh-hans’, ‘Simplified Chinese’),
(‘zh-hant’, ‘Traditional Chinese’)]
LANGUAGES_BIDI
[‘he’, ‘ar’, ‘fa’, ‘ur’]
LANGUAGE_CODE
‘en-us’
LANGUAGE_COOKIE_AGE
None
LANGUAGE_COOKIE_DOMAIN
None
LANGUAGE_COOKIE_NAME
‘django_language’
LANGUAGE_COOKIE_PATH
LIBSASS_CUSTOM_FUNCTIONS
{‘complementary’: <function complementary at 0x7f1d5e3abd90>,
‘scaleby’: <function scaleby at 0x7f1d5e3abd08>,
‘scalebyiv’: <function scalebyiv at 0x7f1d5e3abc80>,
‘theme’: <function theme at 0x7f1d5e3abe18>}
LOCALE_PATHS
LOGGING
{‘disable_existing_loggers’: False,
‘filters’: {‘require_debug_true’: {’()’: ‘django.utils.log.RequireDebugTrue’}},
‘formatters’: {‘simple’: {‘format’: ‘%(levelname)s %(message)s’},
‘verbose’: {‘format’: '%(levelname)s %(asctime)s %(module)s ’
‘%(process)d %(thread)d %(message)s’}},
‘handlers’: {‘console’: {‘class’: ‘logging.StreamHandler’,
‘formatter’: ‘simple’,
‘level’: ‘INFO’}},
‘loggers’: {‘app.logger’: {‘handlers’: [‘console’], ‘level’: ‘INFO’},
‘apscheduler.executors.default’: {‘handlers’: [‘console’],
‘level’: ‘WARNING’},
‘django’: {‘handlers’: [‘console’],
‘level’: ‘WARNING’,
‘propagate’: True}},
‘version’: 1}
LOGGING_CONFIG
‘logging.config.dictConfig’
LOGIN_REDIRECT_URL
‘/dashboard/’
LOGIN_URL
‘/login/’
LOGOUT_REDIRECT_URL
None
MANAGERS
MEDIA_ROOT
‘/webodm/app/media’
MEDIA_TMP
‘/webodm/app/media/tmp’
MEDIA_URL
MESSAGE_STORAGE
‘django.contrib.messages.storage.cookie.CookieStorage’
MESSAGE_TAGS
{40: ‘danger’}
MIDDLEWARE
MIGRATING
False
MIGRATION_MODULES
MONTH_DAY_FORMAT
‘F j’
NUMBER_GROUPING
0
PASSWORD_HASHERS
PASSWORD_RESET_TIMEOUT_DAYS
PREPEND_WWW
False
REST_FRAMEWORK
{‘DEFAULT_AUTHENTICATION_CLASSES’: (‘rest_framework.authentication.SessionAuthentication’,
‘rest_framework.authentication.BasicAuthentication’,
‘rest_framework_jwt.authentication.JSONWebTokenAuthentication’,
‘app.api.authentication.JSONWebTokenAuthenticationQS’),
‘DEFAULT_FILTER_BACKENDS’: [‘rest_framework.filters.DjangoObjectPermissionsFilter’,
‘django_filters.rest_framework.DjangoFilterBackend’,
‘rest_framework.filters.OrderingFilter’],
‘DEFAULT_PAGINATION_CLASS’: ‘rest_framework.pagination.PageNumberPagination’,
‘DEFAULT_PERMISSION_CLASSES’: [‘rest_framework.permissions.DjangoObjectPermissions’],
‘PAGE_SIZE’: 10}
ROOT_URLCONF
‘webodm.urls’
SECRET_KEY
SECURE_BROWSER_XSS_FILTER
False
SECURE_CONTENT_TYPE_NOSNIFF
False
SECURE_HSTS_INCLUDE_SUBDOMAINS
False
SECURE_HSTS_PRELOAD
False
SECURE_HSTS_SECONDS
0
SECURE_PROXY_SSL_HEADER
None
SECURE_REDIRECT_EXEMPT
SECURE_SSL_HOST
None
SECURE_SSL_REDIRECT
False
SERVER_EMAIL
‘[email protected]’
SESSION_CACHE_ALIAS
‘default’
SESSION_COOKIE_AGE
1209600
SESSION_COOKIE_DOMAIN
None
SESSION_COOKIE_HTTPONLY
True
SESSION_COOKIE_NAME
‘sessionid’
SESSION_COOKIE_PATH
SESSION_COOKIE_SAMESITE
‘Lax’
SESSION_COOKIE_SECURE
False
SESSION_ENGINE
‘django.contrib.sessions.backends.db’
SESSION_EXPIRE_AT_BROWSER_CLOSE
False
SESSION_FILE_PATH
None
SESSION_SAVE_EVERY_REQUEST
False
SESSION_SERIALIZER
‘django.contrib.sessions.serializers.JSONSerializer’
SETTINGS_MODULE
‘webodm.settings’
SHORT_DATETIME_FORMAT
‘m/d/Y P’
SHORT_DATE_FORMAT
‘m/d/Y’
SIGNING_BACKEND
‘django.core.signing.TimestampSigner’
SILENCED_SYSTEM_CHECKS
STATICFILES_DIRS
[’/webodm/app/static’]
STATICFILES_FINDERS
[‘django.contrib.staticfiles.finders.FileSystemFinder’,
‘django.contrib.staticfiles.finders.AppDirectoriesFinder’,
‘compressor.finders.CompressorFinder’]
STATICFILES_STORAGE
‘django.contrib.staticfiles.storage.StaticFilesStorage’
STATIC_ROOT
STATIC_URL
‘/static/’
TEMPLATES
[{‘APP_DIRS’: True,
‘BACKEND’: ‘django.template.backends.django.DjangoTemplates’,
‘DIRS’: [’/webodm/app/templates’, ‘/webodm/app/templates/app’, ‘/webodm’],
‘OPTIONS’: {‘context_processors’: [‘django.template.context_processors.debug’,
‘django.template.context_processors.request’,
‘django.contrib.auth.context_processors.auth’,
‘django.contrib.messages.context_processors.messages’,
‘app.contexts.settings.load’]}}]
TESTING
False
TEST_NON_SERIALIZED_APPS
TEST_RUNNER
‘django.test.runner.DiscoverRunner’
THOUSAND_SEPARATOR
TIME_FORMAT
‘P’
TIME_INPUT_FORMATS
[’%H:%M:%S’, ‘%H:%M:%S.%f’, ‘%H:%M’]
TIME_ZONE
‘America/Los_Angeles’
USE_I18N
True
USE_L10N
True
USE_THOUSAND_SEPARATOR
False
USE_TZ
True
USE_X_FORWARDED_HOST
False
USE_X_FORWARDED_PORT
False
VERSION
‘0.8.1’
WEBPACK_LOADER
{‘DEFAULT’: {‘BUNDLE_DIR_NAME’: ‘app/bundles/’,
‘STATS_FILE’: ‘/webodm/webpack-stats.json’}}
WORKER_RUNNING
False
WSGI_APPLICATION
‘webodm.wsgi.application’
X_FRAME_OPTIONS
‘SAMEORIGIN’
YEAR_MONTH_FORMAT
‘F Y’
