Fresh install does not start on MAC
Trying to manually install this on a MAC, Mojave 10.14.5. I got docker running, git’s installed but I get a number of errors when I enter “./webodm.sh start” in Terminal.
I have copied the results after that entry below, bunch of “FAILED” near end
Thanks for any help
Last login: Mon Sep 2 19:32:04 on ttys001
Cengizs-MacBook-Pro:~ goo$ cd WebODM
Cengizs-MacBook-Pro:WebODM goo$ ./webodm.sh start
Checking for docker… OK
Checking for git… OK
Starting WebODM…
Host: localhost
Port: 8000
Media directory: appmedia
SSL: NO
SSL key:
SSL certificate:
Celery Broker: redis://broker
Default Nodes: 1
Starting node-odm … failed
Starting broker … failed
Starting db … failed
Starting worker … failed
Starting webapp … failed
ERROR: No containers to start
ERROR: readlink /var/lib/docker/overlay2/l: invalid argument
Hi @cengiztanc :hand: see Installation Error: No containers to start
The tty file was indeed in another location, and I somehow made it work.
Thank you!!!
