Frequently failed datasets with Mavic 3 Enterprise RTK
I seem to be running into many limitations with either M3E, my flight planning, Lightning, or ODM itself.
I have the 3000 image tier of Lightning but it doesn’t seem to be able to handle more than 2000 images at best. And there are a lot of failed processing attempts.
Often resizing from 96dpi down to 72dpi will result in success.
Typically I use 80% or better overlaps, combined with oblique images.
I got a brand new type of error today:
Any insight on that error?
What is the resolution (in megapixels) of the images coming out of the sensor, and what are you resizing to that seems to succeed?
Comes off sensor at 5280 x 3956, 96dpi
Have seemingly had to resize to 3960 x 2967, 72dpi for all datasets > 1900images
Thank you.
I’ll upstream this to Piero.
Are you able to share the dataset, or a representative sample of it?
