Freezes at reconstruct - Can't find file
Greetings,
Have searched and found some limited information on this topic, of WebODM freezing, but nothing specific for answer.
Have been using on Windows for a while. Last few times when processing it freezes. Last few lines:
2023-05-01 13:33:30,154 DEBUG: Matching MAX_0125.JPG and MAX_0116.JPG. Matcher: FLANN (symmetric) T-desc: 28.861 T-robust: 0.258 T-total: 29.120 Matches: 28 Robust: 9 Success: False
2023-05-01 13:33:30,453 DEBUG: Matching MAX_0160.JPG and MAX_0146.JPG. Matcher: FLANN (symmetric) T-desc: 15.018 T-robust: 0.002 T-total: 15.021 Matches: 1021 Robust: 1011 Success: True
2023-05-01 13:33:30,901 DEBUG: Matching MAX_0214.JPG and MAX_0211.JPG. Matcher: FLANN (symmetric) T-desc: 11.070 T-robust: 0.002 T-total: 11.072 Matches: 123 Robust: 106 Success: True
2023-05-01 13:33:30,914 DEBUG: Matching MAX_0203.JPG and MAX_0127.JPG. Matcher: FLANN (symmetric) T-desc: 23.701 Matches: FAILED
2023-05-01 13:33:30,925 INFO: Matched 1011 pairs (brown-brown: 1011) in 1438.1342012 seconds (1.4224868462908011 seconds/pair).
[INFO] running “C:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\opensfm\bin\opensfm” create_tracks “C:\WebODM\resources\app\apps\NodeODM\data\b35fd1fb-9203-4c46-8313-1277584ccf7c\opensfm”
2023-05-01 13:33:33,837 INFO: reading features
2023-05-01 13:33:38,954 DEBUG: Merging features onto tracks
2023-05-01 13:33:40,891 DEBUG: Good tracks: 128900
[INFO] running “C:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\opensfm\bin\opensfm” reconstruct “C:\WebODM\resources\app\apps\NodeODM\data\b35fd1fb-9203-4c46-8313-1277584ccf7c\opensfm”
That is the last message I receive when it freezes entire system.
When reopened get this message in processing box: b35fd1fb-9203-4c46-8313-1277584ccf7c not found
Current project 110 images, previously processed on same system no problems.
Current setting: Fast Orthophoto (Crashes on all settings this was the latest run)
Running WEBODM version 2.0.1 - Just upgraded, previous version did the same
System:
Windows 10 - all current
Intel i9 10 Gen 3.70 Ghz
Psy RAM 80 GB
HD 549 GB Free
Graphics NVIDIA RTX 2070
No System Errors, No hardware errors
Please advise if I am missing a setting or what to do to correct.
Thank you.
Sorry for the trouble.
Can you tell us a bit more about your dataset and your processing parameters?
That behavior sounds like you’re running out of RAM and are hitting pagefile.
Dataset is
104 images from AUTEL. Each file is apx 1.31 GB
Running: OPTION default of FAST ORTHOPHOTO
Processing Node: NODE-ODM-1 (queue:0)
Resize Images: No
Tried to keep as simple as possible.
Nothing else running on system during processing. This is dedicated to ODM when running.
It was working fine a few months back. Last couple of upgrades started having freezing issue. Been searching for answers for a few months and now at a point where I am lost.
RAM Memory on this machine is 80GB.
Not a programmer, but know basics. Let me know if you have other questions. or recommended settings.
You can try with pc-skip-geometric, which will emulate older behavior.
Also, can you try processing a known-good dataset like Brighton Beach Road?
Sorry don’t know how to download that file set to my system. I click on an image and it opens, but did not want to just save it as I did not know if it keep it’s own data the metafile. So, you gotta help or tell me how to download the set.
Beyond that, I did try to go back to the basics, and resize images down. Also tried to process same images on another system, it worked fine. What I am finding on my system is it is stopping in the same place every time, regardless of settings:
It’s at this point: [INFO] running “C:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\opensfm\bin\opensfm” reconstruct “C:\WebODM\resources\app\apps\NodeODM\data\7e9c546d-fa2d-4744-b5e0-e22937bd3bee\opensfm”
It is always at this same point when it tries to reconstruct. It then gives me an error that it can not find the file. In looking, I can not find it either. Below are the last three runs showing where it stops and freezes up the entire system. I have to hard reset each time.
2023-05-03 20:42:27,753 DEBUG: Matching MAX_0158.JPG and MAX_0155.JPG. Matcher: FLANN (symmetric) T-desc: 2.679 T-robust: 0.001 T-total: 2.680 Matches: 548 Robust: 539 Success: True
2023-05-03 20:42:27,776 DEBUG: Matching MAX_0210.JPG and MAX_0208.JPG. Matcher: FLANN (symmetric) T-desc: 2.393 T-robust: 0.002 T-total: 2.397 Matches: 1491 Robust: 1478 Success: True
2023-05-03 20:42:27,787 INFO: Matched 1012 pairs (brown-brown: 1012) in 200.68723880000002 seconds (0.1983075486166008 seconds/pair).
[INFO] running “C:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\opensfm\bin\opensfm” create_tracks “C:\WebODM\resources\app\apps\NodeODM\data\7e9c546d-fa2d-4744-b5e0-e22937bd3bee\opensfm”
2023-05-03 20:42:30,514 INFO: reading features
2023-05-03 20:42:33,622 DEBUG: Merging features onto tracks
2023-05-03 20:42:36,229 DEBUG: Good tracks: 113570
You can enable the Cloud Import Plugin under the Admin panel, and then use the link I provided to fetch the data.
Are you using WebODM for Windows native or under Docker/WSL2?
I will get a check on this tonight, download the files and advise.
Thank you for the direction on fetching the files.
Got the files as asked, imported fine, run with fast ortho default setting. Crashed again at the same point it did not find the file. Here are all the notes:
Importing 18 images…
[INFO] ==============
[INFO] 3d_tiles: False
[INFO] align: None
[INFO] auto_boundary: True
[INFO] auto_boundary_distance: 0
[INFO] bg_removal: False
[INFO] boundary: {}
[INFO] build_overviews: False
[INFO] camera_lens: auto
[INFO] cameras: {}
[INFO] cog: True
[INFO] copy_to: None
[INFO] crop: 3
[INFO] dem_decimation: 1
[INFO] dem_gapfill_steps: 3
[INFO] dem_resolution: 5
[INFO] dsm: False
[INFO] dtm: False
[INFO] fast_orthophoto: True
[INFO] feature_quality: high
[INFO] feature_type: sift
[INFO] force_gps: False
[INFO] gcp: None
[INFO] geo: None
[INFO] gltf: True
[INFO] gps_accuracy: 10
[INFO] ignore_gsd: False
[INFO] matcher_neighbors: 0
[INFO] matcher_type: flann
[INFO] max_concurrency: 20
[INFO] merge: all
[INFO] mesh_octree_depth: 11
[INFO] mesh_size: 200000
[INFO] name: ec69de78-bd88-4003-8a32-0922721d2996
[INFO] no_gpu: False
[INFO] orthophoto_kmz: False
[INFO] orthophoto_png: False
[INFO] pc_classify: False
[INFO] pc_copc: False
[INFO] pc_csv: False
[INFO] pc_ept: True
[INFO] pc_filter: 2.5
[INFO] pc_las: False
[INFO] pc_quality: medium
[INFO] pc_rectify: False
[INFO] pc_sample: 0
[INFO] pc_skip_geometric: False
[INFO] pc_tile: False
[INFO] primary_band: auto
[INFO] rerun: None
[INFO] rerun_all: False
[INFO] rerun_from: None
[INFO] rolling_shutter: False
[INFO] skip_3dmodel: True
[INFO] skip_orthophoto: False
[INFO] skip_report: False
[INFO] sky_removal: False
[INFO] sm_cluster: None
[INFO] sm_no_align: False
[INFO] smrf_scalar: 1.25
[INFO] smrf_slope: 0.15
[INFO] smrf_threshold: 0.5
[INFO] smrf_window: 18.0
[INFO] split: 999999
[INFO] split_overlap: 150
[INFO] texturing_single_material: False
[INFO] tiles: False
[INFO] use_3dmesh: False
[INFO] use_exif: False
[INFO] video_limit: 500
[INFO] video_resolution: 4000
[INFO] Running dataset stage
[INFO] Loading dataset from: C:\WebODM\resources\app\apps\NodeODM\data\ec69de78-bd88-4003-8a32-0922721d2996\images
[INFO] Loading 18 images
[INFO] Wrote images database: C:\WebODM\resources\app\apps\NodeODM\data\ec69de78-bd88-4003-8a32-0922721d2996\images.json
[INFO] Found 18 usable images
[INFO] Finished dataset stage
[INFO] Running split stage
[INFO] Finished split stage
[INFO] Running merge stage
[INFO] Finished merge stage
[INFO] Running opensfm stage
[INFO] Maximum photo dimensions: 4000px
[INFO] Photo dimensions for feature extraction: 2000px
[INFO] CUDA drivers detected
[INFO] Using GPU for extracting SIFT features
[INFO] [‘use_exif_size: no’, ‘flann_algorithm: KDTREE’, ‘feature_process_size: 2000’, ‘feature_min_frames: 10000’, ‘processes: 20’, ‘matching_gps_neighbors: 0’, ‘matching_gps_distance: 0’, ‘matching_graph_rounds: 50’, ‘optimize_camera_parameters: yes’, ‘reconstruction_algorithm: incremental’, ‘undistorted_image_format: tif’, ‘bundle_outlier_filtering_type: AUTO’, ‘sift_peak_threshold: 0.066’, ‘align_orientation_prior: vertical’, ‘triangulation_type: ROBUST’, ‘retriangulation_ratio: 2’, ‘matcher_type: FLANN’, ‘feature_type: SIFT_GPU’, ‘use_altitude_tag: yes’, ‘align_method: auto’, ‘local_bundle_radius: 0’]
[INFO] running “C:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\opensfm\bin\opensfm” detect_features “C:\WebODM\resources\app\apps\NodeODM\data\ec69de78-bd88-4003-8a32-0922721d2996\opensfm”
2023-05-06 16:44:33,331 INFO: Planning to use 68242.43320312501 MB of RAM for both processing queue and parallel processing.
2023-05-06 16:44:33,334 INFO: Scale-space expected size of a single image : 90.83747863769531 MB
2023-05-06 16:44:33,334 INFO: Expecting to queue at most 200 images while parallel processing of 20 images.
2023-05-06 16:44:33,343 INFO: Reading data for image DJI_0018.JPG (queue-size=0)
REMOVED READING & MATCHING DATA to shorten message length
(symmetric) T-desc: 3.785 T-robust: 0.057 T-total: 3.842 Matches: 25 Robust: 9 Success: False
2023-05-06 16:45:03,580 DEBUG: Matching DJI_0021.JPG and DJI_0022.JPG. Matcher: FLANN (symmetric) T-desc: 4.435 T-robust: 0.001 T-total: 4.437 Matches: 303 Robust: 273 Success: True
2023-05-06 16:45:03,584 INFO: Matched 108 pairs (brown-brown: 108) in 27.2447874 seconds (0.25226655277777776 seconds/pair).
[INFO] running “C:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\opensfm\bin\opensfm” create_tracks “C:\WebODM\resources\app\apps\NodeODM\data\ec69de78-bd88-4003-8a32-0922721d2996\opensfm”
2023-05-06 16:45:04,995 INFO: reading features
2023-05-06 16:45:05,684 DEBUG: Merging features onto tracks
2023-05-06 16:45:05,776 DEBUG: Good tracks: 8635
[INFO] running “C:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\opensfm\bin\opensfm” reconstruct “C:\WebODM\resources\app\apps\NodeODM\data\ec69de78-bd88-4003-8a32-0922721d2996\opensfm”
2023-05-06 16:45:07,633 INFO: Starting incremental reconstruction
2023-05-06 16:45:08,861 INFO: Starting reconstruction with DJI_0025.JPG and DJI_0034.JPG
2023-05-06 16:45:08,905 INFO: Two-view 5-points reconstruction inliers (transposed=False): 1326 / 1328
2023-05-06 16:45:10,192 INFO: Triangulated: 1327
2023-05-06 16:45:11,922 DEBUG: Ceres Solver Report: Iterations: 12, Initial cost: 6.632404e+01, Final cost: 4.399123e+01, Termination: CONVERGENCE
2023-05-06 16:45:12,060 INFO: Removed outliers: 8
2023-05-06 16:45:12,142 INFO: -------------------------------------------------------
2023-05-06 16:45:12,226 INFO: DJI_0033.JPG resection inliers: 495 / 497
2023-05-06 16:45:12,270 INFO: Adding DJI_0033.JPG to the reconstruction
2023-05-06 16:45:12,847 INFO: Shots and/or GCPs are well-conditioned. Using naive 3D-3D alignment.
2023-05-06 16:45:13,535 DEBUG: Ceres Solver Report: Iterations: 26, Initial cost: 3.173214e+02, Final cost: 1.113269e+02, Termination: CONVERGENCE
2023-05-06 16:45:13,775 INFO: Removed outliers: 17
2023-05-06 16:45:13,790 INFO: -------------------------------------------------------
2023-05-06 16:45:13,881 INFO: DJI_0035.JPG resection inliers: 603 / 605
2023-05-06 16:45:13,933 INFO: Adding DJI_0035.JPG to the reconstruction
2023-05-06 16:45:14,558 INFO: Re-triangulating
2023-05-06 16:45:14,559 INFO: Shots and/or GCPs are well-conditioned. Using naive 3D-3D alignment.
2023-05-06 16:45:15,418 DEBUG: Ceres Solver Report: Iterations: 9, Initial cost: 2.444685e+02, Final cost: 1.725388e+02, Termination: CONVERGENCE
2023-05-06 16:45:18,497 DEBUG: Ceres Solver Report: Iterations: 17, Initial cost: 2.462940e+02, Final cost: 1.799098e+02, Termination: CONVERGENCE
2023-05-06 16:45:18,857 INFO: Removed outliers: 36
2023-05-06 16:45:18,880 INFO: -------------------------------------------------------
2023-05-06 16:45:18,971 INFO: DJI_0026.JPG resection inliers: 589 / 593
2023-05-06 16:45:19,023 INFO: Adding DJI_0026.JPG to the reconstruction
2023-05-06 16:45:19,517 INFO: -------------------------------------------------------
2023-05-06 16:45:19,588 INFO: DJI_0032.JPG resection inliers: 564 / 578
2023-05-06 16:45:19,638 INFO: Adding DJI_0032.JPG to the reconstruction
2023-05-06 16:45:20,005 INFO: Shots and/or GCPs are well-conditioned. Using naive 3D-3D alignment.
2023-05-06 16:45:21,230 DEBUG: Ceres Solver Report: Iterations: 9, Initial cost: 1.264736e+03, Final cost: 2.755851e+02, Termination: CONVERGENCE
2023-05-06 16:45:21,736 INFO: Removed outliers: 15
2023-05-06 16:45:21,763 INFO: -------------------------------------------------------
2023-05-06 16:45:21,908 INFO: DJI_0027.JPG resection inliers: 526 / 531
2023-05-06 16:45:21,956 INFO: Adding DJI_0027.JPG to the reconstruction
2023-05-06 16:45:22,375 INFO: -------------------------------------------------------
2023-05-06 16:45:22,462 INFO: DJI_0031.JPG resection inliers: 492 / 496
2023-05-06 16:45:22,505 INFO: Adding DJI_0031.JPG to the reconstruction
2023-05-06 16:45:22,953 INFO: Shots and/or GCPs are well-conditioned. Using naive 3D-3D alignment.
2023-05-06 16:45:24,504 DEBUG: Ceres Solver Report: Iterations: 8, Initial cost: 5.903769e+02, Final cost: 3.841732e+02, Termination: CONVERGENCE
2023-05-06 16:45:25,156 INFO: Removed outliers: 17
2023-05-06 16:45:25,191 INFO: -------------------------------------------------------
2023-05-06 16:45:25,270 INFO: DJI_0024.JPG resection inliers: 492 / 495
2023-05-06 16:45:25,315 INFO: Adding DJI_0024.JPG to the reconstruction
2023-05-06 16:45:25,649 INFO: -------------------------------------------------------
2023-05-06 16:45:25,715 INFO: DJI_0028.JPG resection inliers: 480 / 482
2023-05-06 16:45:25,758 INFO: Adding DJI_0028.JPG to the reconstruction
2023-05-06 16:45:26,180 INFO: Re-triangulating
2023-05-06 16:45:26,182 INFO: Shots and/or GCPs are well-conditioned. Using naive 3D-3D alignment.
2023-05-06 16:45:28,083 DEBUG: Ceres Solver Report: Iterations: 8, Initial cost: 7.723558e+02, Final cost: 5.133101e+02, Termination: CONVERGENCE
2023-05-06 16:45:34,445 DEBUG: Ceres Solver Report: Iterations: 9, Initial cost: 9.479160e+02, Final cost: 5.384446e+02, Termination: CONVERGENCE
2023-05-06 16:45:35,237 INFO: Removed outliers: 83
2023-05-06 16:45:35,278 INFO: -------------------------------------------------------
2023-05-06 16:45:35,333 INFO: DJI_0021.JPG resection inliers: 442 / 447
2023-05-06 16:45:35,374 INFO: Adding DJI_0021.JPG to the reconstruction
2023-05-06 16:45:35,524 INFO: -------------------------------------------------------
2023-05-06 16:45:35,617 INFO: DJI_0022.JPG resection inliers: 431 / 434
2023-05-06 16:45:35,657 INFO: Adding DJI_0022.JPG to the reconstruction
2023-05-06 16:45:35,811 INFO: -------------------------------------------------------
2023-05-06 16:45:35,861 INFO: DJI_0023.JPG resection inliers: 389 / 393
2023-05-06 16:45:35,897 INFO: Adding DJI_0023.JPG to the reconstruction
2023-05-06 16:45:36,066 INFO: -------------------------------------------------------
2023-05-06 16:45:36,116 INFO: DJI_0020.JPG resection inliers: 390 / 393
2023-05-06 16:45:36,152 INFO: Adding DJI_0020.JPG to the reconstruction
2023-05-06 16:45:36,302 INFO: -------------------------------------------------------
2023-05-06 16:45:36,404 INFO: DJI_0030.JPG resection inliers: 239 / 242
2023-05-06 16:45:36,428 INFO: Adding DJI_0030.JPG to the reconstruction
2023-05-06 16:45:36,872 INFO: Shots and/or GCPs are well-conditioned. Using naive 3D-3D alignment.
2023-05-06 16:45:39,558 DEBUG: Ceres Solver Report: Iterations: 19, Initial cost: 1.451865e+03, Final cost: 7.186207e+02, Termination: CONVERGENCE
2023-05-06 16:45:40,539 INFO: Removed outliers: 36
2023-05-06 16:45:40,587 INFO: -------------------------------------------------------
2023-05-06 16:45:40,677 INFO: DJI_0029.JPG resection inliers: 333 / 334
2023-05-06 16:45:40,708 INFO: Adding DJI_0029.JPG to the reconstruction
2023-05-06 16:45:41,229 INFO: -------------------------------------------------------
2023-05-06 16:45:41,304 INFO: DJI_0019.JPG resection inliers: 244 / 248
2023-05-06 16:45:41,329 INFO: Adding DJI_0019.JPG to the reconstruction
2023-05-06 16:45:41,440 INFO: -------------------------------------------------------
2023-05-06 16:45:41,542 INFO: DJI_0018.JPG resection inliers: 115 / 117
2023-05-06 16:45:41,555 INFO: Adding DJI_0018.JPG to the reconstruction
2023-05-06 16:45:41,667 INFO: -------------------------------------------------------
2023-05-06 16:45:41,671 INFO: Shots and/or GCPs are well-conditioned. Using naive 3D-3D alignment.
2023-05-06 16:45:44,554 DEBUG: Ceres Solver Report: Iterations: 15, Initial cost: 1.041873e+03, Final cost: 8.297815e+02, Termination: CONVERGENCE
2023-05-06 16:45:45,646 INFO: Removed outliers: 17
2023-05-06 16:45:46,067 INFO: Reconstruction 0: 18 images, 8509 points
2023-05-06 16:45:46,067 INFO: 1 partial reconstructions in total.
[INFO] running “C:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\opensfm\bin\opensfm” compute_statistics --diagram_max_points 100000 “C:\WebODM\resources\app\apps\NodeODM\data\ec69de78-bd88-4003-8a32-0922721d2996\opensfm”
2023-05-06 16:46:07,431 DEBUG: locator: <matplotlib.colorbar._ColorbarAutoLocator object at 0x000001A48C67C1C0>
2023-05-06 16:46:07,431 DEBUG: Using auto colorbar locator <matplotlib.colorbar._ColorbarAutoLocator object at 0x000001A48C67C1C0> on colorbar
2023-05-06 16:46:07,431 DEBUG: Setting pcolormesh
2023-05-06 16:46:08,387 DEBUG: locator: <matplotlib.colorbar._ColorbarAutoLocator object at 0x000001A48A5351C0>
2023-05-06 16:46:08,387 DEBUG: Using auto colorbar locator <matplotlib.colorbar._ColorbarAutoLocator object at 0x000001A48A5351C0> on colorbar
2023-05-06 16:46:08,387 DEBUG: Setting pcolormesh
[INFO] running “C:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\opensfm\bin\opensfm” export_geocoords --reconstruction --proj “+proj=utm +zone=15 +datum=WGS84 +units=m +no_defs +type=crs” --offset-x 576705.0 --offset-y 5188170.0 “C:\WebODM\resources\app\apps\NodeODM\data\ec69de78-bd88-4003-8a32-0922721d2996\opensfm”
[INFO] Updating C:\WebODM\resources\app\apps\NodeODM\data\ec69de78-bd88-4003-8a32-0922721d2996\opensfm\config.yaml
[INFO] undistorted_image_max_size: 2000
[INFO] Undistorting C:\WebODM\resources\app\apps\NodeODM\data\ec69de78-bd88-4003-8a32-0922721d2996\opensfm …
This is where it freezes up. Locks up the screen and whole system.
It did not used to do this. It used to work fine. now… can’t get it to stop freezing.
As I am not good on the line edits of everything, I think I am using WEBODM for WIndows… I purchased and using the download installer for windows on this. As said, origionally worked fine, but seems the last couple of upgrades are now not working.
Is there a way I can remove this entriely from my system, getting rid of all previous files, references, everyting and try to reinstall it? Or if you have other suggestion, pelase advise.
Thanks,
Yep, you can run the uninstall from the Control Panel to remove it, delete the directory it installed to (C:\WebODM), and then remove the AppData Folder for it (%AppData%\WebODM).
Thanks,
Will try that to see if there is some strange setting or something that is off. Will advise.
Latest…
  1. Uninstalled via Control Panel
  2. Deleted from Directory
  3. Deleted from App Data
  4. Ran Disk search to find any other indication of program
  5. Turned off and restarted to clear any memory
  6. Checked Registry for anything remaining (could not find)
  7. Rechecked hard drive for any thing on program
After all clear turned off and reinstalled.
  • Loaded B. Beach images to process
  • Processing on default
Freezes up again at reconstruct. When reopen it tells me file not found error.
Went though above and tried one more time, but run as system administrator thinking that maybe it had something to do with writing.
Same error again at same point. It hits that section and all things stop. No mouse movement, no keyboard access, the entire system just freezes.
No other programs on this system are doing this. It is setup and used as a graphic system, running mostly adobe products and this one. Memory on disk is wide open, High RAM, Graphic Cards, etc… all built for processing data. It was being used to process the drone images, until it started freezing.
Let me know if there is something else I should be checking for. I am at a total loss on this on especially in that it was working fine when first installed apx. 7/23/22.
At this point, it sounds like disk or filesystem corruption, unless you are running an anti-virus other than Windows Defender.
Running only defender for anti-virus. For disk, running SSD on this one. I will have the system recheck the disk. Nothing found when previously checked. And no other programs are having an issue.
Will run some more check and advise.
If the regular way of doing the chkdsk doesn’t turn anything up, I can advise on how to perform a system check that is more rigorous.
