FreeBSD install script
Hi everyone !
I have Freenas with plenty of memory so I’m current working on a install script to install webodm in a jail.
It’s have really been a pain to iron out all the problems that I have encounter on this journey but now I find my self beaten.
My current script …
#!/bin/tcsh
pkg update -f
pkg upgrade
pkg install -y nano						# Nano (text editor)
pkg install -y postgresql11-server postgresql11-client  	# install postgres
sysrc postgresql_enable=yes  					# enable at boot in  /ect/rc.conf
/usr/local/etc/rc.d/postgresql initdb				# init the database
                                                # make postgresql listen to all addresses
echo "listen_addresses = '*'" >>  /var/db/postgres/data11/postgresql.conf
/usr/local/etc/rc.d/postgresql initdb				# Initialize the database
                  # make all  connection,user,databases available
echo "host  all  all  0.0.0.0/0  md5" >>     /var/db/postgres/data11/pg_hba.conf
/usr/local/etc/rc.d/postgresql start 				# start postgresql
								# Setup of WebODM database
su - postgres -c "psql -c "\""CREATE USER postgres WITH PASSWORD 'postgres'"\"";  "
su - postgres -c "psql -c "\""ALTER ROLE postgres WITH PASSWORD 'postgres'"\""; "
su - postgres -c "psql -c "\""ALTER ROLE postgres WITH SUPERUSER"\""; "
su - postgres -c "createdb -O postgres webodm_dev -E utf-8"
su - postgres -c "psql -d webodm_dev -c "\""SET postgis.enable_outdb_rasters TO True;"\"" "
su - postgres -c "psql -d webodm_dev -c "\""SET postgis.gdal_enabled_drivers TO 'GTiff';"\"" "
	# Install misc package
pkg install -y postgis30-3.0.1_2 	# Postgis
pkg install -y python3			# Python3
pkg install -y gdal                     # Gdal
pkg install -y py37-gdal-3.1.0
pkg install -y node 			# Node.js
pkg install -y grass7-7.8.3		# Grass
pkg install -y nginx			# Ngnix
rehash  				# make tsch aware of the new application
sysrc nginx_enable="YES"		# enable nginx at boot
/usr/local/etc/rc.d/nginx start 	# start nginx
pkg install -y git			# Git
rehash                                  # Make system aware of installed git
                                        # Fetching WebODM
git clone --depth 1 https://github.com/OpenDroneMap/WebODM
					# Generate cfg file.
touch WebODM/webodm/local_settings.py
cat > ./WebODM/webodm/local_settings.py<<EOF
DATABASES = {
    'default': {
        'ENGINE': 'django.contrib.gis.db.backends.postgis',
        'NAME': 'webodm_dev',
        'USER': 'postgres',
        'PASSWORD': 'postgres',
        'HOST': 'localhost',
        'PORT': '5432',
EOF
pkg install -y redis				# install redis
sysrc redis_enable="YES"			# enable redis at boot
/usr/local/etc/rc.d/redis start			# start redis
						#redis-server /usr/local/etc/redis.conf    	# start redis broker
pkg install -y py37-pip				# install pip
rehash						# make system aware of pip
echo "Installing numpy will take a while"
pip install numpy                               # numphy used by requirements.txt
pip install -r ./WebODM/requirements.txt	# install WebODM requirements
pkg install -y npm				# Node Package Manager
npm install -g webpack
npm install -g webpack-cli
# npm install --package--lock
webpack --mode production
tzsetup			# set local timezone
python3 ./WebODM/manage.py collectstatic --noinput
chmod +x ./WebODM/start.sh 			# Make executable
# https://www.grymoire.com/Unix/Sed.htmlx
	# replacing python with python3 in ./WebODM/starts.sh
	# fixing the shebang
if ! ( -f ./WebODM/start.sh.bak) cp ./WebODM/start.sh ./WebODM/start.sh.bak    	# make a copy if runned first timne
cat ./WebODM/start.sh.bak | sed s:python:python3:g > ./WebODM/start.sh.new     	# using the copy and replace with python3
cat ./WebODM/start.sh.new | sed 's:#\!\/bin\/bash:#\!\/bin\/sh:' > ./WebODM/start.sh	# finally replace the shebang (to #!/bin/sh ) and save to start.sh
 ./WebODM/start.sh --no-gunicorn
# greppa ip nummer nedan
# ifconfig | sed -En 's/127.0.0.1//;s/.*inet (addr:)?(([0-9]*\.){3}[0-9]*).*/\2/p'
# /var/db/postgres/data11/hb_pga.conf
echo *** end **
My first problem is missing “raster”.
Applying app.0001_initial…Traceback (most recent call last):
File “/usr/local/lib/python3.7/site-packages/django/db/backends/utils.py”, line 83, in _execute
return self.cursor.execute(sql)
psycopg2.errors.UndefinedObject: type “raster” does not exist
LINE 1: …d_control_points" varchar(100) NULL, “orthophoto” raster NUL…
This would also make the GRASS engine to fail and so on.
Anyone with some skills of Feebsd and this postgres raster problem ?
