Update: I re-ran the individual datasets and got the same failure using “Forest” settings.
Attached is the pdf report from running one of the flights with the “Default” settings and below is the task output for the failed “Forest” settings report.pdf (9.0 MB) (image load text removed for brevity):
[INFO] Initializing ODM - Wed Apr 21 04:39:22 2021
[INFO] ==============
[INFO] build_overviews: False
[INFO] camera_lens: auto
[INFO] cameras: {}
[INFO] crop: 3
[INFO] debug: False
[INFO] dem_decimation: 1
[INFO] dem_gapfill_steps: 3
[INFO] dem_resolution: 5
[INFO] dsm: False
[INFO] dtm: False
[INFO] end_with: odm_report
[INFO] fast_orthophoto: False
[INFO] feature_quality: ultra
[INFO] feature_type: sift
[INFO] force_gps: False
[INFO] gcp: None
[INFO] geo: None
[INFO] gps_accuracy: 10
[INFO] ignore_gsd: False
[INFO] matcher_distance: 0
[INFO] matcher_neighbors: 8
[INFO] matcher_type: flann
[INFO] max_concurrency: 22
[INFO] merge: all
[INFO] mesh_octree_depth: 11
[INFO] mesh_size: 200000
[INFO] min_num_features: 18000
[INFO] name: a6a23204-48cc-49ec-895c-da0a679f4862
[INFO] orthophoto_png: False
[INFO] pc_classify: False
[INFO] pc_csv: False
[INFO] pc_ept: False
[INFO] pc_filter: 2.5
[INFO] pc_las: False
[INFO] pc_quality: medium
[INFO] pc_rectify: False
[INFO] pc_sample: 0
[INFO] primary_band: auto
[INFO] rerun: None
[INFO] rerun_all: False
[INFO] rerun_from: [‘dataset’, ‘split’, ‘merge’, ‘opensfm’, ‘openmvs’, ‘odm_filterpoints’, ‘odm_meshing’, ‘mvs_texturing’, ‘odm_georeferencing’, ‘odm_dem’, ‘odm_orthophoto’, ‘odm_report’]
[INFO] resize_to: 2048
[INFO] skip_3dmodel: False
[INFO] skip_report: False
[INFO] sm_cluster: None
[INFO] smrf_scalar: 1.25
[INFO] smrf_slope: 0.15
[INFO] smrf_threshold: 0.5
[INFO] smrf_window: 18.0
[INFO] split: 999999
[INFO] split_overlap: 150
[INFO] tiles: False
[INFO] time: False
[INFO] use_3dmesh: False
[INFO] use_exif: False
[INFO] verbose: False
[INFO] Running dataset stage
[INFO] Loading dataset from: /var/www/data/a6a23204-48cc-49ec-895c-da0a679f4862/images
[INFO] Loading 306 images
[INFO] Wrote images database: /var/www/data/a6a23204-48cc-49ec-895c-da0a679f4862/images.json
[INFO] Found 306 usable images
[INFO] Parsing SRS header: WGS84 UTM 55S
[INFO] Finished dataset stage
[INFO] Running split stage
[INFO] Finished split stage
[INFO] Running merge stage
[INFO] Finished merge stage
[INFO] Running opensfm stage
[INFO] Writing exif overrides
[INFO] Maximum photo dimensions: 4000px
[INFO] [‘use_exif_size: no’, ‘flann_algorithm: KDTREE’, ‘feature_process_size: 4000’, ‘feature_min_frames: 18000’, ‘processes: 22’, ‘matching_gps_neighbors: 8’, ‘matching_gps_distance: 0’, ‘optimize_camera_parameters: yes’, ‘undistorted_image_format: tif’, ‘bundle_outlier_filtering_type: AUTO’, ‘align_orientation_prior: vertical’, ‘triangulation_type: ROBUST’, ‘retriangulation_ratio: 2’, ‘feature_type: SIFT’, ‘use_altitude_tag: yes’, ‘align_method: auto’, ‘local_bundle_radius: 0’]
[INFO] running /code/SuperBuild/src/opensfm/bin/opensfm extract_metadata “/var/www/data/a6a23204-48cc-49ec-895c-da0a679f4862/opensfm”
2021-04-21 04:39:33,431 INFO: Extracting EXIF for DJI_0395.JPG
2021-04-21 04:39:58,979 INFO: Extracting EXIF for DJI_0414.JPG
[INFO] running /code/SuperBuild/src/opensfm/bin/opensfm detect_features “/var/www/data/a6a23204-48cc-49ec-895c-da0a679f4862/opensfm”
2021-04-21 04:40:00,440 INFO: Extracting ROOT_SIFT features for image DJI_0395.JPG
2021-04-21 04:40:00,440 INFO: Extracting ROOT_SIFT features for image DJI_0288.JPG
2021-04-21 04:40:00,440 INFO: Extracting ROOT_SIFT features for image DJI_0472.JPG
2021-04-21 04:40:00,441 INFO: Extracting ROOT_SIFT features for image DJI_0465.JPG
2021-04-21 04:40:00,441 INFO: Extracting ROOT_SIFT features for image DJI_0527.JPG
2021-04-21 04:40:00,441 INFO: Extracting ROOT_SIFT features for image DJI_0539.JPG
2021-04-21 04:40:00,441 INFO: Extracting ROOT_SIFT features for image DJI_0509.JPG
2021-04-21 04:40:00,441 INFO: Extracting ROOT_SIFT features for image DJI_0444.JPG
2021-04-21 04:40:00,441 INFO: Extracting ROOT_SIFT features for image DJI_0467.JPG
2021-04-21 04:40:00,441 INFO: Extracting ROOT_SIFT features for image DJI_0278.JPG
2021-04-21 04:40:00,441 INFO: Extracting ROOT_SIFT features for image DJI_0547.JPG
2021-04-21 04:40:00,441 INFO: Extracting ROOT_SIFT features for image DJI_0454.JPG
2021-04-21 04:40:00,442 INFO: Extracting ROOT_SIFT features for image DJI_0282.JPG
2021-04-21 04:40:00,442 INFO: Extracting ROOT_SIFT features for image DJI_0341.JPG
2021-04-21 04:40:00,442 INFO: Extracting ROOT_SIFT features for image DJI_0413.JPG
2021-04-21 04:40:00,442 INFO: Extracting ROOT_SIFT features for image DJI_0535.JPG
2021-04-21 04:40:00,442 INFO: Extracting ROOT_SIFT features for image DJI_0446.JPG
2021-04-21 04:40:00,442 INFO: Extracting ROOT_SIFT features for image DJI_0263.JPG
2021-04-21 04:40:00,442 INFO: Extracting ROOT_SIFT features for image DJI_0347.JPG
2021-04-21 04:40:00,442 INFO: Extracting ROOT_SIFT features for image DJI_0335.JPG
2021-04-21 04:40:00,442 INFO: Extracting ROOT_SIFT features for image DJI_0440.JPG
2021-04-21 04:40:00,443 INFO: Extracting ROOT_SIFT features for image DJI_0304.JPG
2021-04-21 04:40:01,061 DEBUG: Computing sift with threshold 0.1
2021-04-21 04:40:01,062 DEBUG: Computing sift with threshold 0.1
2021-04-21 04:40:01,083 DEBUG: Computing sift with threshold 0.1
2021-04-21 04:40:01,084 DEBUG: Computing sift with threshold 0.1
2021-04-21 04:40:01,086 DEBUG: Computing sift with threshold 0.1
2021-04-21 04:40:01,105 DEBUG: Computing sift with threshold 0.1
2021-04-21 04:40:01,107 DEBUG: Computing sift with threshold 0.1
2021-04-21 04:40:01,108 DEBUG: Computing sift with threshold 0.1
2021-04-21 04:40:01,111 DEBUG: Computing sift with threshold 0.1
2021-04-21 04:40:01,118 DEBUG: Computing sift with threshold 0.1
2021-04-21 04:40:01,156 DEBUG: Computing sift with threshold 0.1
2021-04-21 04:40:01,199 DEBUG: Computing sift with threshold 0.1
/code/SuperBuild/src/opensfm/bin/opensfm: line 12: 1078717 Killed “$PYTHON” “$DIR”/opensfm_main.py “[email protected]”
app.execute()
File “/code/opendm/types.py”, line 360, in run
File “/code/opendm/types.py”, line 341, in run
File “/code/stages/run_opensfm.py”, line 32, in process
File “/code/opendm/osfm.py”, line 279, in feature_matching
self.run(‘detect_features’)
File “/code/opendm/osfm.py”, line 27, in run
system.run(’%s/bin/opensfm %s “%s”’ %
Exception: Child returned 137
