Hi everyone.
I wanted to know if there is any possible way to remove fish eye from photos.
I am currently releasing models with the following photos (attached some of them).
the problem is that I can’t find options to calibrate the image or tell webodm the focal point of my camera.
reason why webodm generates the models like this:
Anyone knows how to solve this? that is, the model appears flat …
Thank you very much in advance!!
When you process your images, make sure to use the --camera-lens
fisheye
parameter/task setting.
yes, i use the --camera-lens
fisheye
parameter, but the problem persist…
my opstions are these:
I also use a gcp_list with control points.
but the final model is still curved … :
Mm, that was my best guess. Perhaps there’s something going on with the GCPs. It’s difficult to tell without the input images and a copy of the GCP file.
mm ok, i share my input data:
https://drive.google.com/drive/folders/1H7Z5Z0XgpmRBVO9TESPVKSDkycO3jbP2?usp=sharing
in that link I leave my photos and my gcp list…
any idea what may be going on?
Thanks in advance!
