Dear WebODM user,
this is my first time using WebODM. This morning, I flew my DJI Mavic mini 1 on a sample mapping mission using DroneLink.
I flew in a grid pattern resulting in 159 images. However, when running the default mapping task in WebODM in my browser, the task fails with exit code 137. A search indicates this might be due to a RAM limitation. My Docker is set to default at 2GB of RAM. What would you guys recommend, is running these tasks locally recommended at all? I’ve now set Docker to 8GB and will run again. How do I know how much RAM is required for a task? (Ballpark estimate)
Link to your images:
Y2021M02D21_Drone_map_test_v01 - Google Drive
Entire task output (not just parts of it) for everyone to read:
- Did you fine tune any parameters? Which ones?
I tried a few options including “Default”, “High Resolution” and Fast Ortho
- If applicable, what browser are you using? What operating system? How did you install the software? Be precise.
MacBook Pro (13-inch, 2020, Four Thunderbolt 3 ports)
16 GB 3733 MHz LPDDR4X
2 GHz Quad-Core Intel Core i5
Intel Iris Plus Graphics 1536 MB
