FileNotFoundError -- ClusterODM
Running a dataset through ClusterODM that I previously ran through as a single dataset. The dataset has some camera calibration challenges associated with being a belly landing fixed-wing with a commodity camera, so I though localizing the camera errors might be useful, and what better approach than doing that with split merge.
Version: latest versions of WebODM, ClusterODM, and NodeODM, up-to-date as of today (Sept. 12, 2021). Updated using docker pull on latest images.
So here is what I see during the second stage of remote submodel processing:
FileNotFoundError: [Errno 2] No such file or directory: '/var/www/data/caec6ac0-05dd-484d-8a26-56bf7e0fefb8/opensfm/exif/deduped2016-09-13_08.59.58.JPG.exif'
Full log saved at /var/www/data/845a57fa-1b8d-49d2-927e-278898888009/submodels/submodel_0010/error.log
[INFO]    LRE: Cleaning up remote task (caec6ac0-05dd-484d-8a26-56bf7e0fefb8)... OK
If I look for more detail in the log on that remote machine, I see something like this:
useruser@nodex:~$ docker cp hungry_allen:/var/www/data/845a57fa-1b8d-49d2-927e-278898888009/submodels/submodel_0010/error.log .
useruser@nodex:~$ tail error.log
exif = {image: self.load_exif(image) for image in self.images()}
File "/code/SuperBuild/install/bin/opensfm/opensfm/dataset.py", line 981, in <dictcomp>
File "/code/SuperBuild/install/bin/opensfm/opensfm/dataset.py", line 579, in load_exif
with self.io_handler.open_rt(self._exif_file(image)) as fin:
File "/code/SuperBuild/install/bin/opensfm/opensfm/io.py", line 1349, in open_rt
return cls.open(path, "r", encoding="utf-8")
File "/code/SuperBuild/install/bin/opensfm/opensfm/io.py", line 1341, in open
return open(*args, **kwargs)
If I check to see if that exif file seems corrupted or similar, I get the following:
useruser@nodex:~$ docker cp hungry_allen:/var/www/data/845a57fa-1b8d-49d2-927e-278898888009/opensfm/exif/deduped2016-09-13_08.59.58.JPG.exif .
useruser@nodex:~$ more deduped2016-09-13_08.59.58.JPG.exif
    "make": "SONY",
    "model": "DSC-WX220",
    "width": 4896,
    "height": 3672,
    "projection_type": "brown",
    "focal_ratio": 0.0,
    "orientation": 1,
    "capture_time": 1473753586.693,
    "gps": {
        "latitude": -5.788261138888889,
        "longitude": 39.29726327777777,
        "altitude": 261.167,
        "dop": 20.0
    "band_name": "RGB",
    "camera": "v2 sony dsc-wx220 4896 3672 brown 0.0 rgb"
I’ve got a couple of these cropping up in a 7k image dataset. I could pull these out of the process and rerun, but I am curious if there are any insights on what is happening to trigger this error.
Mm, not sure, but doesn’t seem to be an isolated case.
If you can reproduce this consistently, can you setup a (small) test case (images, parameters, etc.)?
You don’t want a 7k image test case?
Yeah, let me see what I can do that’s reproducible.
:laughing:
