Maybe this is redundant. I get pretty frustrated about marking a polygon for measurements and then my click speed is not perfect and I waste the time that I have very carefully taken to mark an object usually for volume measurement in my case. The poly closes and I cannot edit the points. It is a huge time bandit and a source of frustration having to delete and start over.
So, my request is to be able to edit a polygon within the measurement tool in 2d mode. Thanks.
Or use QGis
I do not care for the qgis volume tool. You have mentioned it to me before I think in a thread. I tried it and do not like it.
Sometimes you just need to learn the tool to appreciate it. It may take some time.
And sometimes people will not agree with you. It doesn’t mean you are dull. It just means they do not agree.
Thanks, Some day I will finally learn the correct procedure.
Let’s agree to disagree!
agreed
