Failure when processing 3d model
I don’t typically use drone deploys 3D enhanced mapping when capturing a data set. Well I did this time and when I try to run the images I get a failure. I can process the images from the cross grid without the perimeter images just fine. When I try to process all the images I am getting a failure. I can not share the data set but have the console log. The data set consist of 176 images total.
I see in the console log
[INFO] Found 176 usable images
then a few lines later
2022-01-27 19:09:29,368 INFO: Expecting to process 193 images.
Here is the full log
Did you re-run this dataset at any point?
Could you try a clean run from load-images?
I did try 3 times to re-run, twice was with loading the images as a new project with different default settings. Then I tried without the perimeter images just to see if I got the error and it finished. I have another project running atm but planned to try the perimeter images to see if they processed.
Try to increase the mesh size higher and try to set quality to ultra. You may need more details. Would you please tell us a little bit about your dataset?
Well just as a update on this. I tried this data set a couple more times even default with same error and stop point.
Today I updated the docker images and restarted webodm and booyah! I had no errors and was able to process without a hitch.
Great to hear the error was disappear. :smiley:
Sometimes If I had any error, restarting Docker and WebODM on Linux Terminal is fixing my problem
cd WebODM
./webodm.sh stop
sudo service docker restart
./webodm.sh start --gpu
O, I defiantly brought webodm down and up more than a few times. :wink:
I am not sure what the issue was, cause it would build a empty point cloud then failing afterwards.
