While trying to update my WebODM installation from 1.9.0 to 1.9.7 (build 32) The update will download and then produce the error message below
When I select ‘OK’ the update stops and the program closes. I am running on Windows 10 and have all the recommended system requirements. I run the software on an external 14 TB hard drive.
Does anyone have any advice on how I can complete the upgrade?
I am using Norton 360, I have disabled it and retried but alas the same error message appears. The file path of the ‘file in use’ is C:\Users\Owner\AppData\Local\Temp\WebODM_Setup.exe.
