Orthophoto when displayed in WebODM:
Same orthophoto when exported to KMZ and opened in Google Earth:
Why is the KMZ transparency not working in GE?
The KMZ export in WebODM was buggy for some time.
It was mentioned here on the forums and the devs know about it.
… 2min later …
Ahja, to try it out I just exported a project in KMZ and now it works correctly:
WebODM is version 2.0.1 and ODM is 3.1.0
If you use the Docker version just run ./webodm.sh update
and it should pull the latest versions.
Thanks, that worked. I did run update yesterday and something updated, not sure what, but I did notice that the interface showed v1.9 something. I wasn’t sure what the latest version was. Today’s update looked different than yesterday’s and it did update to v2.0.1.
So much thanks and all is right in the world now.
