Export maps from the quality report
Hi all,
Is it possible to export the maps from the report: Track Details, Feature Details, and Survey Data? Or if they are part of the standard export, where should I look for them in the output?
Also, based on other forum discussions, the UserData feature in the .las outputs contains the information on the count of images (views) that each point has been seen (What are the integer data in UserData column of output from webODM?). Is this information at all related to the SurveyData map in the report (eg mean count at some resolution), or is it something different?
Thank you!
