Expired SSL certificate doesn't auto renew
Looks like the Lets Encrypt ssl cert expires after 60 days and needs to be renewed manually. Though the documentation “https://github.com/OpenDroneMap/WebODM” says
"That's it! The certificate will automatically renew when needed."
but my certificate has expired and no luck even after restarting with “./webodm.sh restart --ssl”…
I had to start in non-ssl mode and then ssl mode to have the new cert. Has anyone faced this situation or any other way to automate?
Mm, in theory this should already be automated (there’s a cronjob inside the docker container that should take care of it), but perhaps for some reason it’s not working.
Check the crontab file inside the container?
docker exec -ti webapp bash
crontab -e
You can also force the cert to upgrade by invoking the nginx/letsencrypt-autogen.sh script from the container.
