Exception: Child returned 137
I am new to opendronemap and I am trying out the software.
I dont know if this is the category used for bugs, but I couldnt find one for that.
The code in general runs fine when using the default parameters, but when I change some parameters some errors appear.
I got similar errors when using the following flags (independently):
–min-num-features 12000
–mesh-size 300000
I am using the dataset “crop field” found here:
This is the error that I get…
Generating texture patches:
Running… Killed
File “/code/run.py”, line 57, in
app.execute()
File “/code/opendm/types.py”, line 370, in run
File “/code/opendm/types.py”, line 351, in run
File “/code/stages/mvstex.py”, line 97, in process
‘-n {nadirWeight}’.format(**kwargs))
Cheers!
Looks like you’re running out of memory (not enough RAM). Search the forum for “running out of memory”, you’ll find some good suggestions :slight_smile:
Thank you for the advice…
I am running the calculation in a machine with 32Gb of RAM, and it seems it is not enough! :slight_smile:
I checked the other posts and I found some interesting options.
I will try to resize the images first!
Thank you for the help!
