Errors occur when running nodeODM on ubuntu 20.04
On ubuntu 20.04, I run the command line:
sudo docker run -p 127.0.0.1:3000:3000 --gpus all opendronemap/nodeodm:gpu
Then open the website 127.0.0.1:3000, load images and press the ¨StartTask¨ button, errors occur as follows:
UUID: 0c73f5a0-340d-45c6-a4c5-46bbdc3fa502
Name: Task of 2021-10-29T02:35:15.246Z
Images: 26
Status: Failed
Time Elapsed: 00:02:16
Console Output: Hide | Export
File “/code/opendm/mesh.py”, line 207, in screened_poisson_reconstruction
system.run(’"{reconstructmesh}" -i “{infile}” ’
[ERROR] Uh oh! Processing stopped because of strange values in the reconstruction. This is often a sign that the input data has some issues or the software cannot deal with it. Have you followed best practices for data acquisition? See Flying Tips — OpenDroneMap 2.6.4 documentation
Can you give me a hand? Thank you.
Seems the same issue that was fixed a day ago; try updating?
Indeed! This work now, so you need pull the new docker image :slight_smile:
I pulled the docker image several times, but not the latest version.
Can you share me with the command line you employed?Thanks.
Delete the local docker image and then pull again with the regular command, that should be the way to go!
docker image rm | Docker Documentation
OpenDroneMap/NodeODM: A lightweight REST API to access aerial image processing engines such as ODM or MicMac (github.com)
